Question about Electrolux Vacuums
Electrolux B22 Floor Polisher - Drive Belt Replacement
Can you please provide information on the procedure for replacing the drive belt on an Electrolux B22 Floor Polisher. I have recently purchased a new belt (Electrolux P/N: 102335007). Regards
2 Suggested Answers
  • 70 Answers
SOURCE: Need replacement belt PN 43409 for Electrolux Commercial Upright
Just about any vac shop should have the belt. This belt is the same belt used in the upright vacs as well as the power nozzels. The new oem part number is 48359.
Posted on Oct 22, 2009
Burning rubber smell when vacuum running
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Most times that burning rubber smell is the result of a worn out rubber drive belt. This belt is used to drive the rotating beater brush in the head of your vacuum. When the belt gets old and loose, the drive pulley starts to spin in place and heats up the belt instead of turning it properly.
To fix this issue, just unplug your vacuum, then disassemble the bottom head in order to access the beater brush drive belt. Remove the old belt, then replace with a new one, and then reassemble it. The old belt will probably have a part number on it so you know which type to buy, or you can just look up your vacuum model number online to find the correct replacement part for it.
Since you did not provide your vacuum's exact model number, here is a link to a short video which demonstrates the basic belt replacement procedure for a generic vacuum cleaner:
http://www.youtube.com/watch?v=T11KkkFspos
To view the video instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Nov 28, 2011 | Kenmore Vacuums
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
My powerhead drive belt to the N137A electrolux model has broken. I have a new belt for replacement but do not know how to install.
Turn the PN bottom up. With a Phillips screwdriver, remove the six screws in the base. Turn PN over and lift back of cover, then gently manipulate it until it comes off.
Slide the belt off motor shaft, if necessary. Remove the screws on each end of the brush and lift the end of the brush so you can remove the belt, if necessary. Place new belt on brush and place brush into slot. Replace screws and tighten. Pull belt back to motor shaft and slip on. Check belt for tautness. There should be a little play, but not much. Make sure belt is placed correctly and rotate brush a few turns.
I recommend cleaning the inside of the PN while you have it apart. Use the dust brush to vacuum as much as possible out.
Make sure the light cover is in the correct position. Carefully place front lip of PN cover into slot in front.of the PN. Carefully settle cover in place. Check around the PN to ensure cover and base are correctly placed. Turn PN over and replace screws, short one in front.
I do recommend letting a trained Aerus Electrolux tech do this, especially since the belt will have a one year warranty if he/she does it. Of course the belt should last longer than that, anyway.
Mar 03, 2011 | Electrolux Epic 6500 Vacuum
The plastic drive unit were the brushes attach have two of the four plstic ribs broken, this is the one located on the end of the motor, I will to replace
Electrolux Floor Pro shampooer and polisher (Aerus)
I'm not sure what your question is, but you'll probably need to take this to an Aerus Electrolux store for repair. They may not have the parts on hand, but can order them for you. While there, ask them to show you how to remove the brushes, or be sure to tell everyone who uses it how.
Jan 19, 2011 | Electrolux Floor Pro Vacuum
Does the epic 3500 have a belt? It seems that when running on the carpet setting, it is very noisy and is not picking up the way it should. When we run it on the floor setting, it sounds better, but the...
Yes, it does. It definitely sounds like a broken belt. And the noise would probably be due to the belt still being in the machine and hitting the motor shaft.
Due to some difficulty in reassembling the powerhead and getting the belt to the correct tension, I strongly recommend taking it to your local Aerus Electrolux store for replacement. Ask the tech to clean it while you're there.
http://www.aerushome.com/storelocator/
Jan 15, 2011 | Electrolux Epic 3500 Vacuum
How to check the belt?
I have listed a link to the manual for your model and a link to the replacement belt you need. Hope it helps!
Manual
Electrolux Epic 3500 Replacement Belt
Oct 29, 2009 | Electrolux Epic 3500 Vacuum
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Hello. I have an electrolux glider upright bagless vacuum cleaner (UK model) who's brushes do not rotate any more. I'm guessing that I need to replace the drive belt but I have no idea where to start. I...
Hello! There are two solutions to this as the Glider model you speak of could be the more old fashioned type where screws on the bottom foot plate (ie where the spinning brush sits) have to be undone in order to get to the drive belt.
However if you have blue/red/Harmony Glider type model, the drive belt location is on the top of the hood where the floor selector is. There are three screws to undo here; one sits just underneath the main hose to the left hand side of the machine (and can be tricky to take out) if looking at the machine from the front, whilst right at the front of the machine, you'll see two other cross head screws which need to be undone. Make sure that the rotary height dial is out of the way - the top hood should then pop open revealing the brush. Then just take out brush by grabbing the beater bar and pull upwards gently. Take off the old belt, put on a new one around the spindle motor and then onto the beater bar and push the brush roll back in.
Unfortunately you may need brute strength for this as a new belt is often tensioned.
Dont forget to rate. Thanks.
Jul 26, 2008 | Electrolux Vacuums
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
555 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
