Question about Proform Crosswalk 500 Treadmill
Belt makes noise, like it is scrapping something!
    President:
  • 1,126 Answers
Do you have a three year old in the house?? Our ProForm 795 treadmill started making noise when the belt was rotating. Come to find out, he had hidden a plastic clothes hanger inside where the drive roller spins the belt. That was our scaping noise.
Otherwise, is your belt tensioned correctly? If not, it could be tracking to one side or the other.
Posted on Nov 17, 2009
I have a Hyundai accent 2005. Bought it 3 months ago. Every time i push the gas pedal, it makes a noise. Noise is not too bad, but what could it be? Please help
would you describe the noise 1 metallic/scrapping, 2 slight roar ,3 squeal, 4 something else
1,loose drive belt pulleys, something may have dropped onto driven parts
2. loose or worn air intake hose , air filter box not secured
3. alternater etc drive belts , spray WD40 onto them when revving engine , if squeal goes check condition of belts
4. can you describe it
hope this gives you a starting point
Jul 08, 2015 | 2005 Hyundai Accent
What wrong with my vacuum?
I expect something is rubbing on the beater bar or belt. Remove the beater bar and belt and look for a paper clip, scrap of material, etc.
Jan 07, 2015 | Sebo ET-1 Powerhead White
Noise
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
electronics repair help
Jun 28, 2014 | Exercise & Fitness
A scrapping noise from the bottom left corner.
if its a dryer then you have a bad tub wheel or something got down in the tub inside
Jan 15, 2013 | Washing Machines
A very annoying whine when riding until you hit 110k plus
Could be several things, but lets check the less exspensive solutions first.
Chain/Belt guard bolts loose and scrapping tire or belt.
If shaft drive, check/add gear oil.
Get a piece of wood and put it against the motor and the other end to your ear.
Now put it against the transmission
Now put it on the clutch cover
Listen to see where the sound is more prominent(noticeable).
If motor you may be hearing a stiff timing chain, check/change oil & filter first, then listen again
if tranny, you may need to change your oil, if you hear the gaers whining. good clean oil will quiet a noises tranny.
Clanks , clucks, rattles, are not good noises
a whining noise could be something simple to worn out bearings.
Check to make sure that nothing is rubbing first,(misplaced saddlebag,loosened guard)
Listen with a stethescope or piece of wood if the noise is hard to locate.
Dec 08, 2010 | 2000 Yamaha Royal Star Venture
The belt is making a scraping noise when you walk on it. i see nothing touching the belt proform crosswalk 375e
Unplug the treadmill then loosen the running belt and physically feel the full length of the deck and then chick the entire running belt something is stuck causing the scrapping.
May 15, 2010 | Exercise & Fitness
My volvo 850 making noise in left turns
You have a bad CV joint ... get it fixed right away or more damage can occur....and the car wont move if it does go all the way out.
Sep 15, 2009 | 1996 Volvo 850
Dryer is making a scrapping noise like something needs oil
Most common thing causing scrapping noise on tumble dryers is the drum bearing worn. Listen carefully at the back of the machine when it is going and you will confirm the noise is louder there, if so a new drum bearing is required. There is a small removable panel in the middle of the outer back panel where the bearing is. Spares are available at your local suppliers
Aug 23, 2009 | GE Dryers
How can i tell if compressor is bad
In the worst case the shaft will be frozen and when the compressor clutch engages, your serpetine belt will smoke and fall off. Before that, if you have the proper Freon pressure and the compressor clutch engages, it will make a noise like loose marbles scrapping inside a cylinder.
There is suppose to be oil in the compressor, a certain weight like motoroil differs, get the right one. There are cans of Freon which have an oil charge in them. You add it to the low pressure side of the system just like regular Freon. Sometimes you can get lucky and add it and the noise will go away and there is no damage. Other times the parts are pitted and the oil will lube them up and its too late.
If your A/C is not putting out and not making noise, then it is something else like a simple recharge or fixing a leak.
Jul 10, 2009 | Chevrolet K2500 Cars & Trucks
Proform Crosswalk 500 Treadmill Logo
1,107 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
