Question about Riso RZ220 Duplicator
What does the error code P04-513 means ? Risograph
    New Friend:
  • 17 Answers
P04-513 means ink overflow. Don't worry though, sometimes this is not always the case. The ink sensor inside the drum has two antennas, a short one a long one. The long one is always supposed to have ink on when sticking into the ink bead. If it doesn't it calls for the ink pump to turn on and draw ink from the bottle. If the short one ever gets ink on it, this error code comes up. Sometimes it is just caused by ink splattering inside.
Take off the drum screen and drum body. Inside, you will see these two antennas in the ink bead. Clean out most of the ink and make sure the small antenna has no ink on it. Reassemble.
Posted on Mar 30, 2010
Risoguy hit it right on the head - but - if you are like me, and have no idea how to take off the drum screen and body --- all around the two ends of the drum are small machine screws - you have to take the 4 out that hold the piece that clamps down the master, and remove the clamp - then all the screws around the two ends - 2 on each side have slotted holes in the drum body, so just loosen them - you need them to realign the drum body and screen when you put them back on. I kept the screen and body together when i did it. on the bottom is the big roller, covered with ink - if you look between that roller and the center of the drum, you will see the piece with two stiff wires, one short and one long - the short one needs to be cleaned completely of ink. When I put mine back together, it worked like a charm!
Posted on Apr 07, 2010
3 Suggested Answers
  • 81 Answers
SOURCE: Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Posted on Jul 07, 2009
  • 81 Answers
SOURCE: risograph rp 3100 ui
Reset machine... and check connectors to the boards... its a communications error to the digitizer cpu
How to solve e13 error in risograph ks 800
E13 Cutter motor Lock
• If the Cutter home position switch is not turned OFF within 500 ms after the Cutter motor is activated.
• If the Cutter end position switch is not pressed within 2000 ms after the Cutter motor is activated. http://printcopy.info/?l=en&mod=free&chap=erc&brand=Riso&model=KS800
Apr 17, 2015 | Washing Machines
What is error code P-98-934 means for Risograph EZ 220U model
I face p98-35 on my risograph ez220u ,..and i cant find it at my technical service book....once i switched on the machine and the code come out...what is the problem of my machine?
Oct 14, 2014 | Office Equipment & Supplies
What is a T11 error code mean on a Risograph GR3750?
this problem is on pressure motor, stay in rear part machine,i don´t remember of the code for testing. after i put here, if you need pass e- mail for luizalexdias@hotmail.com
May 05, 2010 | Riso RZ220 Duplicator
Risograph RA4050 diplaying error code E11, anyone know what that means? Has recently been putting masters on the drum crooked and making grinding noise.
E11 is the pressure control motor encoder has nothing to do with the master problem it is most likely out of time. (grinding noise)
May 03, 2010 | Riso RZ220 Duplicator
Mar 11, 2009 | Riso Office Equipment & Supplies
Risograph rp 3100 ui
Oct 13, 2008 | Riso RZ220 Duplicator
Code d--13, ---9 risograph rz220
Check out copytechnet.com. Its a free service that covers copiers only. You can get in touch with a Risograph technician to give you the answer.
Oct 08, 2008 | Office Equipment & Supplies
Risograph 5800 repair
This is a cutter moter lock. you would have to replace the cutter unit.
Nov 10, 2007 | Office Equipment & Supplies
3,736 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
