Question about Candy CDC266 Dryer
A capictor blew up
I'm pretty sure a capictor blew up, (from the bang and the smell). Is this a common problem. I am an engineer so I would readily tackle this if I had a manual. Any advice appreciated
  • Candy Master
  • 3,463 Answers
It is not an unusual prob, they can just fail for no apparent reason
It is usually fond in the top of the washer, where the mains cable comes in, a very easy job to replace.
Please rate my solution.
Thanks.
Posted on Nov 17, 2009
    Genius:
  • Candy Master
  • 1,460 Answers
The cap is a mains filter, common..Simple to do for an engineer cost of part £8...approx...
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
Dec 26, 2015 | Dyson DC41 Animal Bagless Upright Vacuum...
I am not sure what is going on but I am pretty sure that I shouldn' t have to be putting in coolant into my car 2 times a month. The car temperature is just fine ( always stays between C and H ) and...
Check your radiator hoses going into your engine. Best case, you may just have a leak that is dripping onto your engine, hence the smell. Worst case, take a look at your exhaust when your car is operating at normal temperature. If there is white smoke coming out, you may have a cracked engine block, the coolant is leaking into your engine and produces white smoke from your exhaust when it is burned.
Sep 29, 2013 | 1998 Toyota RAV4
Engine blew up on 2nd season of use, only 40.8 hrs. of run time.
Check the engine crankcase bolts have not come loose, i have seen this on some Briggs engines.
Sep 10, 2012 | Garden
2002 dodge intrepid, 2.7 L engine, the top of the Engine Coolant Outlet Flange blew off. What does this part do and what could cause it to literally blow off (top blew off from body of flange)?
that is the water outlet housing. It is really common for this to happen. It has probably been leaking for quite some time (usually a bunch of dried up coolant around that area).
They are fairly easy to replace and the parts are usually readily available. I'm pretty sure NAPA caries them as well as the dealer.
You will need to remove the intake plenum to get at one of the bolts that hols it in place. Its not that big of a deal to remove. Just remember to replace the plenum gasket and torque the bolts to the proper spec.
If you have any questions I'll be happy to answer them.
Sep 03, 2011 | 2001 Chrysler Sebring
Chrysler new yorker with a 3.0 liter v-6 engine burns and smells oil and stalls when hot. Can anything be done other than change the engine to fix or improve this problem?
Bad valve guides and seats were pretty common item on those 3.0L engines in those days. Caused oil to leak in beside guides and into cylinder, especially at idle, or after hard acceleration, then let off (highest vacuum ) when warm. If your handy at all, heads can be done pretty reasonably at engine shop, or even get a set of heads from newer engine, when problem was cured.
Jul 14, 2010 | 1989 Chrysler New Yorker
My 1995 4X4 3.0L engine head gasketfailed at 251K km and was replaced at a cost of about $2400CDN. Coolant in the block damaged the bearings and the engine blew 30K km later. It was replaced at a cost of...
Here in the US the NTSB can be contacted online or by phone. National Traffic Safty Board surely has a Canadian counterpart. They will have a list of TSB(technical Service Bullitins) and recalls. But it's 15 years old and they probably don't apply anymore. 251 K is pretty long life though. I had 362K on a GMC 350, then it blew the head gasket too.
Feb 05, 2010 | 1991 Toyota Xtracab
Washing machine went bang and smells burnt
May be hard to find what went bang for you/ could be motor. / Heater/ wiring/ printed circuit panel, Advise get engineer to check.
Nov 28, 2009 | Coffee Makers & Espresso Machines
Head gasket/ timing etc
Not 100% sure on that engine, but I'd be looking at my timing chain & gears, especially if gears have nylon teeth. Pull covers & have a look at condition & positioning for correct. Other thing I'd check is distributor & especially gear at end of shaft. If metal gear at bottom, you should be o.k.,but if nylon,could have melted.heated & distorted or broke. Be sure to mark it for re-install & don't crank engine before re-install.
Feb 23, 2009 | 2000 Pontiac Grand Am GT
Petrol smell from engine
I think you might be only intermittantly noticing it.
Check around the fuel injectors for signs of wetness as soon as you notice it again. Failure of the metal-plastic junctions is pretty common. Their expansion and contraction rates are different so eventually, the seal can fail.
Dec 09, 2008 | 1995 Toyota Previa
Candy CDC266 Dryer Logo
108 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
