Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
My PT-45LC12 has picture and fan problems
My PT-45LC12 45 lcd screen shut off with the audio remaining on. I noticed at this point the fan was not running with no front panel fault lights, so I switched the unit off. I unplugged it for 1/2 hour and then tried to turn it on. The green power light flashes but no sound , no picture and no fan operation. Is this typical of a fan failure? Is this an easy fix or should my dealer/repairman be involved?
DH
  • Jet Mech Jan 11, 2008
    Thanks for your help. I'm on my third bulb and I did change just the bulb last time for a big savings. Did you mention class action. My next question is, will a blown bulb shut down the cooling fan?
    DH
  • Anonymous Jun 17, 2008
    need to know how to change just the bulb i the lamp case?
  • 579 Answers
More like lamp failure. Could be other things of course but start with the lamp cause it will need it anyway if has been a couple years.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Hope ya fix it!
Posted on Jan 10, 2008
6ya staff
SOURCE:
Samsung LCD LN46B630. Backlight flickers for 2 sec. then shuts off. Audio is good and a bright flashlight shows video when directed towards front of LCD panel. BL will immediately turn back on with a...
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 30, 2017 | Samsung Televison & Video
JVC jle42bc3001 LCD TV has a thin blank line running through the right/mid section of the screen. Obviously more noticeable when the picture/scene is light. Is this repairable?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 17, 2016 | JVC Televison & Video
What should I replace next, I have a samsung lcd with no backlights but picture shows with a flashlight in a dark room.
sir,
even if you changed the back light inverter the fault remain as same, it seems to be the back light LED is damaged carefully remove the outer frame of the panel then dis connect the LCD then remove the frame of the defuser screen , take out plug your TV, check the LEDs
Feb 15, 2016 | Samsung LN46E550 46 inch LCD HDTV 1080p...
Why does the lamp shut off on the Panasonic PT-AE1000E Projector within 1 minute of starting?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 26, 2014 | Panasonic PT-AE1000E Projector Lamp...
Turns on white i can hear the audio and change through the cable channels with my comcast remote.The vizio remote will turn the tv on & off but none of the other buttons work and the screen remain
tcon board fault. If you wish to get some details; visit the site linked here. Pull up older posts.
Nov 19, 2017 | Vizio VOJ370F 37 in. LCD TV
Green pixels appear at top area of screen after about one hour of use. Repair man said I needed a new display monitor for 3500. I noticed the two small fans located near the top of TV inside the panel not...
Sep 04, 2017 | Pioneer PureVision Pro-1000HD 50 in....
I have colored spots appearing on my screen when the TV is on. The spots are 2 to 6 inches in diameter and always appear in the same locations at various places on the screen. The first spots I noticed...
the light engine (optical block) is failing. there are lcd panels and light filters in the light engine. the problem your having is that they over heated and the image is burnt into the lcd or light filter. my be caused by a failing fan or just it's life span. the lcd panel or light filter are done for. you can keep calling panasonic and bug them over and over and they may send you a new tv. sony sent me one after 5 phone calls. i had the same problem. hope this helps.
Jan 14, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I have a Panasonic PT-50DL54J DLP projection TV. It suffers from a shut down problem. Shortly after powering up, the TV shuts off, and the front LED flashes red 6 times. At this point, the TV will not...
I have similar problems. I removed the back panel and use compressed air to blow out all the dust from all the components. Just remember not to blow into the main fan on the right as that is the one cooling the lamp. I don't know for sure if this is the only problem.
Dust built up caused heat built up on the components.
Nov 15, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Orange and red light blinking after one minite
I fixed this problem by disassembling the panels. On the front then sides then back of the unit. The first thing I noticed was some debris in the exhaust fan wheel on the back side. I used some long wood skewer to fish out the debris and even shook the unit upside down. (It's very heavy and would recommend help with shaking the unit.) Also, I think i found a little sensor that is about the size of a thumb drive and incased in a transparent plastic box. I tapped it with my finger and noticed this little black thing bounce up and down inside under the green circuit board. its located right above the drain connection. I didn't do anything else with this. I assumed its the sensor to measure the water buildup. I also found a small toy in the front fan wheel that blows the cool air through the top of the unit. fell out during the shake down. The final thing I noticed was when re-assembling the unit. On the front side you will see the two metal radiator looking panels. Between the two panels is a wire sensor that looks like a temperature measuring device. I had noticed it was touching the metal part of the radiator panel so I gently streightened it out so that it was parallel with the panels and not touching. I pressed the power button and it hasn't shut of yet. I snapped the front panel back on and all is good.
I have the white upright sharp AC unit with the three lights in the front and a power button next to the IR sensor. I lost the remote control and couldn't figured out why the unit would start up then shut down after a minute of use. The operation light would blink red then the orange timer light would blink next. Then both lights would blink simultaneously, then repeat. I thought this was a timer setting. but the unit is supposed to reset after disconnected from the power.
Sep 30, 2009 | Sharp Heating & Cooling
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
