Recently when I connect my wife Sansa clip 2GB to my computer it is not turning on (showing connection/charging) and the computer does not reconized it. But when I unplug it, it turns on. The player is getting some charge but not fully(never had any problems with it in the past)
I also have a Sansa clip 2Gb but not having any problems with it on my computer.
Any assitance would be greatly appreciated.
Thanks....
SOURCE: where can i find the driver for sansa clip mp3 2gb?
Can I use Sansa Clip MP3 Player together with MacBook and Mac OS X v. 10.4
Ulla
SOURCE: SanDisk Sansa c200 2Gb won't turn on
Some recent Windows updates have caused problems as severe as this on many mp3 players regardles of manufacturer (the iPod has been immune because it is not Windows-based). If you have either Windows Vista or Windows Media Player 11, which are the latest versions, then perform a firmware update on your Sansa player by going to the Sansa website and getting the firmware updater:
http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
SOURCE: sansa clip mp3 player 2GB shows as UNKNOWN DEVICE when i connect
Sandisk website will have it, and will have the vista compatible software:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
here is the link for the sansa updater.
Ok...here is something you might want to do....I know you already formatted your device a zillion times already but please do it one more time using the Format option under Settings menu in your device....then restart your computer....then plug in your computer again after restarting to see if it recognizes now.....if not...here is one thing you could do....go to this link
http://www.nirsoft.net/utils/usb_devices_view.html
download the USBDeView software and see if the registry has the player in there....select it and delete it and then plug in your PC again to see if it will re-register the device and works...hope this will help.
SOURCE: sansa clip mp3 player driver 2GB
The drivers and all software is available from Sandisk's website.
SOURCE: when i connect my sansa clip 2GB to my computer it
just figured mine out. turn your clip off. put the slider in the hold or lock position. press and hold the center button on your clip. continue to hold while attaching the usb to your clip. keep holding the center button as clip powers up. after appox. 12-15 seconds, your computer should read the clip. i am running windows xp and this is the ONLY way my comp. will read the clip. but it works great!! good luck!
