Question about Whirlpool LSQ9600L Top Load Washer
Hi! Thanks for free help, I have a washer(whirlpool LSQ9200PQ4) I found a problem, sometimes, the water is leaking while wateris filling Please give an idea at my e-mail:tkim47@gmail.com Thanks again from: teddy
If i check resistor i dont know if this is damage
Posted on Nov 17, 2009
There is an open hole in the bottom of the water
This is simply a pressure bleed-off.
You can fill it with playdough...sillyputty (gum) etc. It should have had a wax-like plug from the factory.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine leaks water as tank is filling up.
Hi
If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Kenmore Washing Machines
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Wont fill with water
Hi, Check the drain hose to make sure it hasn't dropped lower than the water level in the washer.
Sometimes when working on the machine, the drain hose gets moved. Does the drain hose go into a sump pump?
PLEASE let me know if this helps or if I can assist you further.
Vic
Jun 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool washer leaks when filling. We have located that it leaks from the plastic liner. Therefore leaking water onto floor.
Hi, The plastic liner you are talking about, is it the outer tub? If you could get me a model#, I could look this up for you.
Please let me know if I can help.
Vic
Jun 01, 2009 | Washing Machines
Whirlpool Duet Washer Leaking
Hi, If you are getting water in the washer without it running, the inlet mixer valve is going bad. When you run a load, does it finish spinning and all the water is out? I hope this helps you. It is not an expensing repair. I can walk you through the repair if you would like.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No water pressure on fill.
Hi, If you have checked the screens in the mixer valve and there is nothing plugging it, then it is most likely the mixer valve.
I hope this helps. Please let me know and feel free to rate my response to you.
Thanks
Vic
May 20, 2009 | Kenmore 22422 Top Load Washer
Washer
Wow...your posting was hard to read, but I managed to "muddle" through it. I understand that you need laundry and experienced no leaks of any kind. Well...I don't have a good answer for as to what may be wrong. You could have experienced a momentary leak due to heavy vibration from an unbalanced load, or...you had a minor leak that sealed itself over time, I just don't know. That's the nature of this business sometimes. This is also why customers get frustrated by repeated service calls when the appliance doesn't do what it was doing wrong when the repairman shows up. Then, as soon as the repairman disappears down the street, the problem comes back. Believe me, I've seen this over and over. The best advice I can give you for now is to continue to monitor your washer with the cardboard underneath. If the problem comes back, no matter how minor, get back to me and let me know where it is leaking. Until then, if the washer does NOT have any problems continue to use it as you normally would. Good luck to you Tom.
PS To avoid confusion - to get back to me, all you have to do is reply to this post with your comments and I will receive an email notification.
Oct 04, 2008 | Washing Machines
Kenmore Elite washer
Okay...what you are talking about is a honey colored oil, right? The gearcase (transmission) is filled with this oil. Sometimes the gearcases are prone to leaks. There is a small breatehr hole onthe top of the gearcase housing that oil will sometimes weep out of when it expands. This could be a potentially serious problem, as a leaky gearcase COULD mean it is beginning to fail. But...not always. This is kind of a gray area when it comes to this model washer. As leaking oil is generally considered a bad thing, the gearcase could actually run for quite a long time and experience no failures, or further leaks. I would keep the oil cleaned up and run the washer as you normally would. If the leaking becomes progressively worse, the tub begins to spin slower than usual, requires assistance to spin, clothes aren't spinning dry enough, or if the gearcase starts to exhibit loud noises, stop using the washer and plan on needing a replacement gearcase. They generally run about $150 and can easily be installed by the DIYer. If you wish to pursue that as an option sometime, just let me know and I can provide you with the steps required to do so. At this point, monitor what you have and let me know how much the gearcase is leaking.
As far as the water leaking is concerned...you need to determine WHERE it is coming from. If it is leaking in the center under the wash tub in the location of the gearcase, the tub seal probably needs replaced, or you may have a crack in the tub somewhere. If the washer is leaking near the front, this is generally a sign of a leaking water pump, or associated hoses. Check to make sure the hoses are clamped snug. If the washer is leaking in the back somewhere, I would suspect a leaking water inlet hose, or drain hose. The best way to make the determination is to place a sheet of cardboard under the washer when it is empty. Do a load of wash and pull the cardboard out when done. Note where the leak patterns are and get back to me. I need to know where the water is coming from before I can give you a correct assessment. I hope this helps guide you in the right direction.
Oct 01, 2008 | Washing Machines
Washer
You bet, the tub seal is out and also the clutch and drive tub assemblies need to be replaced because like a drum brake oil has contaminated the pads. Did you notice that if you open the lid while spinning that it takes longer than seven seconds for the basket to stop? See the pic below, you need parts 1 and 5 plus the tub seal and center post seal.
Sep 30, 2008 | Washing Machines
Whirlpool LSQ9600L Top Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
