Question about Dell 3010cn Laser Printer
Dell 3010cn white stripe
Dell 3010cn 90% to the right of the page is a full length 1/4'' white strip.
Seems as though toner is not applied there, affects all colors.
  • trevor bisssett Jul 18, 2012
    Thanks for this solve. The only white stripes I will encounter from now on will be those of the musical variety.
    Problem Solver:
  • 6 Answers
On the 3010cn open from cover, follow instruction for pulling up the lever and sliding the bar out of the side repeat the slide motion 15 to 20 time. this action cleans the printing plate and will elimiate the strip. the strip is caused be toner leaking on to the plate it the strip returns repeat the steps.
Posted on Dec 01, 2009
This also solved the problem! I actually tried several times and finally I moved the cleaning strip in and out quite vigorously and it finally worked! You may also want to make sure the cleaning pad on the strip is clean! Thanks!
Posted on Feb 06, 2012
Thank you - that solved our problem.
(asked in previous question)
Posted on Jan 19, 2010
  • Teresa Schillinger Nov 09, 2011
    It sounded ridiculous, but this absolutely worked or me too.
  • Ben Deighan Sep 27, 2012
    It worked for me too! Go FixYA!
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
Brownish stripe (vertically) down the middle of the page
Replace the drum. the toner is in tubes, and uses a common drum. the drum is replaceable. Go to your local refiller, and get it done quickly.
Jan 27, 2011 | Dell 3010cn Laser Printer
Dell 3010cn printer, Printing on right side ends of the page is faded.
There could be dust/ Toner Dust accumulated on the mirrors and lenses inside the printer, which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hope this helps! Dont forget to appreciate the solution!!
CreativeTECH
Dec 13, 2010 | Dell 3010cn Laser Printer
White stripe on right as if black toner needs
You probably got a piece of paper or something in the image path or the paper path. If it is a nice clean line it is more likely to be in the image path, if it is smudgy line it something may be scraping the toner off the paper before it gets to the fuser. Check the paper path.
Dec 26, 2009 | Dell 3010cn Laser Printer
Stripe right side
is this strip white? or another color? if its white take a q-tip and clean the scanner window. you do this from inside the printer. on the roof of the compartment youll find a grove about 3/16 wide and as wide a a piece of paper stick the q-tip in there be gentle and slide it back and fourth across the length of the grove if the q- tip is dirty you got the problem.
if the strip is black you have one of 2 things the thermister on the fuser has hit bare metal or a leaking toner cartridge
Nov 04, 2009 | Dell 3010cn Laser Printer
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
My DELL 3010CN is printing a thick black line on the right hand margin on all pages printed.
Often Toner sticks to fuser. When the fuser heats the toner comes off onto the paper. Should reduce over time unless toner is spilling onto the fuser in the same place.
Change fuser and toner
thanks
Apr 08, 2009 | Dell 3010cn Laser Printer
Quarter inch vertical white stripe down length of copy
Make sure that the corona wire is clean (use a dry bristle haired artists paint brush or use the cleaning pad supplied with the printer) and making sure that the toner cart cleaner / scraper is not clogged or has some paper jammed on it. Also you can vacuum the Corona Wire with a domestic vac and the nozzle tool or a clean soft brush tool but make sure the printer is turned off before doing it.
Mar 22, 2009 | HP LaserJet 3050 All-In-One Printer
Dell 3010cn Laser Printer Logo
550 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
