Washer will not spin. it fills with water, then you hear a humming but will not spin in any cycle
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
If pump is working okay then could be motor not turning drum/ if no pump then try cleaning filter....
Posted on Nov 17, 2009
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Ge GTWN2800D1WW washer wont fill on start but will do drain and spin cycle....help
What do you mean? It not fill up or no water is coming in?
Did you hear some humming noise?
Check the input water tap... close be closed or blocked...
Dec 01, 2015 | GE Washing Machines
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Filled up with water on rinse cycle but wont work
Possible fault in the control panel , could be that the sequential switching to the next cycle is not outputted due to a failed device - a relay.
Remove the panel and check for dry soldering or parts that are burnt in your observation. Also check the voltage in the spin cycle and if this is absent the panel is a suspect as the processor does not advance from the memory set.
Jul 03, 2012 | Admiral Washing Machines
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore 23012, spin cycle problem
This sounds like a broken coupler gear. I'm having the same problem with my Kenmore-80 Series. The machine fill up, pump out, but when I try to spin I get nothing and the I can hear the motor humming/grinding. I've heard the coupler gear is not expensive $35 or so and the repair procedure is not difficult, but I can't locate how to fix it. If you find any additional information, please send my way. I don't want to pay $150 or so to have it serviced.
Mar 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
