Question about Canon PowerShot A470 Digital Camera
Canon powershot a470 card locked - Canon PowerShot A470 Digital Camera
  • Canon Master
  • 4,738 Answers
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera.
But if you have already tried this, see this link for additional things that you can try.
Posted on Nov 17, 2009
  • Canon Master
  • 3,289 Answers
This is nearly always an indication of an issue with the memory card, not the camera. I have had a similar problem with flimsy lock tabs on memory cards myself. I solved it by placing a small amount of scotch tape over the tab - starting near the connection pads, over the tab to the back edge of the card. There's usually not a whole lot of extra room in the slot, so insert carefully and remove portions of tape as needed.
Worst case scenario - if you never use the locking tab (I never do) you could place a small dab of super glue to hold it in place. Let it "set up" before reinserting - you don't want the tab to move an be held on the lock position.
The tab may very well become repositioned as it is being inserted into the camera, and then repositioned again when it is removed. If the tab is loose, it will probably be nearly impossible to determine with any certainty how and when it is occurring, unless it is prevented from moving with tape or glue described above.
I hope you found this Very Helpful and good luck!
  • 203 Answers
SOURCE: Driver
windows should plug and play that camera with generic drivers-if not get memory card reader and download pics straight to comp w/reader and bypass camera
Posted on Aug 17, 2008
  • 51 Answers
SOURCE: Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
Posted on May 20, 2009
michel_mmvi
  • 44 Answers
SOURCE: memory card locked
this is from cardrecovery.com... whew a lot of people get this error... hope all of u resolves this..
but before u truobleshoot for recovery of pictures, check first the slide on your memory card (card protection) slide it both ways and check it... someone advices from a thread to use paper clips to pick the slot of the cam where u put the card, it work for him but i think its not a good idea coz it may damage the slot.. okay.. if there is still an error u can bring it to a tech person (canon support service) or just try to recover ur files...
Troubleshoot:
Memory card is used by digital camera to store the photos it takes. Popular memory cards include SD card, CF card, xD-Picture card and Memory stick. For some reasons, memory card may get damaged on power shortage, or removal of memory card on picture shooting or viewing, or other various and unknown reasons. Usually, you will see error message like "memory card error", "card locked", "card error", or an error code on your camera screen and the valuable pictures on the memory card could disappear and be lost. Some cases, your camera or Windows may prompt you to re-format the memory card and refuse to take new pictures or view old pictures.
Solution:
Once you have your memory card damaged, it is highly recommended to stop further operations on the memory card (e.g. taking new pictures, or delete, format the memory card). Data recovery software like "CardRecovery" is able to recover the lost pictures in most cases.
First, you need to confirm your memory card can appear as a drive letter in "My Computer", which will allow recovery software to access and recover the lost photos. You may try to connect your digital camera to your computer, if a new drive letter appears in "My Computer", it is OK. Otherwise, you need to prepare a USB card reader. There are many card readers available in market (e.g. SanDisk and Kingston). You can buy one from Amazon or BestBuy.
Then, you may download and install CardRecovery to your computer. Launch it from Start Menu -> Programs -> CardRecovery. You select the drive letter of your memory card, and destination folder for save the recovered files. CardRecovery will scan your memory card and locate the recoverable pictures. The process is quick and easy. Usually it takes less than 15 minutes.
Can I re-use the corrupted memory card?
For data protection, CardRecovery performs read only operation on your memory card and it does not change the data on the memory card, so it does not repair or fix the memory card. If you need, AFTER you have recovered your lost photos from the card, you may try to format the memory card before re-use. It is suggested to perform enough read/write test before using it again to take new pictures. If you are worrying that the memory card is unstable and may cause further data loss, purchase and use a new memory card. Your valuable and irreplaceable photos are more important than memory card. Memory card is very cheap. A new 2GB SD, CF or xD card is less than $10.
Posted on Sep 13, 2009
dlundmark
  • 797 Answers
SOURCE: canon powershot A470 problem when i click photo
Go to the menus and find the set to default option.
This should reset the menus and options to original.
Go to the menu section find a setting something like this... such as.. reset all to default or set to factory default or simply RESET.
Check to see if the pictures are saved to the card by taking a picture, then remove the card and play it back in either another camera or use a card reader to read the card.
If these tests shows that no picture was taken or it is all white, then the camera needs repair or has a ccd problem.
Another option is to call Canon Repair at the following page and use the 800 number for calling the repair department.
Canon has a trade-up or trade-in program which is a great way to get another camera at a good price. Canon will allow you to trade in your camera for a reasonable price against a refurbished camera plus a cost which is reasonable. A refurbished camera will come with everything it had when new, and will have been restored to original specifications.
Posted on Oct 27, 2009
Ranglo
  • 1194 Answers
SOURCE: Canon Powershot A470 Screen reads Lense error ,
This error occured when lens is prevented from properly extending or retracting.when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed due External shock or liquid, sand & dirt etc. enters the camera.
Avoid applying pressure to the lens and surrounding area:
1) Do not touch Lens while shooting.
2) Make sure the camera is off before the camera is placed back in the case.
If you cannot clear the error code by turning the camera OFF and then ON again then your device need to be repaired.
Rating the solution is highly appriciated...Good Luck.
Posted on Mar 06, 2010
My memory card is in the locked position in my Canon Power shot A470 how do I unlock it
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 07, 2011 | Canon PowerShot A470 Digital Camera
How do i unlock my memory card from my canon powershot A470
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 25, 2010 | Canon PowerShot A470 Digital Camera
THIS IS THE SECOND MEMORY CARD THAT HAS GOTTEN LOCKED IN MY CANNON A470 CAMERA. IT SAYS "CARD LOCKED!"
Nov 16, 2010 | Canon PowerShot A470 Digital Camera
My canon A470 is writing card lock
There is a tiny slide switch on the SD card. It locks the card. Slide it to the unlocked position.
May 31, 2010 | Canon PowerShot A470 Digital Camera
My canon power shot A470 is writing card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I have a Canon PowerShot A470. When I go to
Is the slide switch on the side of the card in the locked position?
Dec 16, 2009 | Canon PowerShot A470 Digital Camera
May 20, 2009 | Canon PowerShot A470 Digital Camera
Memory card locked on canon A470 digital camera
take the card out of the camera and look at it closely. You'll see the LOCK switch.
Mar 24, 2009 | Canon PowerShot A470 Digital Camera
With my Canon Powershot A470 it keeps saying card locked
Have you tried to pull out the card and see if there is a little slide lock on the card? if so try sliding the slide lock to the unlock position. if it's already unlocked, try accessing the card via your computer. You might need to format the card if it's new. I've run into this problem in the past with some new memory cards.
Another solution you might try is putting the card into the camera and see if there's a function in the setup menu that will format or unlock the card from within the camera. It's a longshot but worth looking into.
Feb 20, 2009 | Canon PowerShot A470 Digital Camera
Canon PowerShot A470 Digital Camera Logo
738 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
