Question about OfficeMax 0M96431 Shredder
I inserted paper covered with polythene and now the shredder wont start or turn. the polythene has tightly locked the shredder. it is a jielisi make.
  • 1,959 Answers
There's only 1 true way to unblock the teeth, that's to put it in reverse to try to remove paper from the feeder channel. After that, unplug the unit, turn the head upside down and "dig" the paper out with a small knife, flathead screwdriver, or tweezers. The paper will come out a little at a time but eventually will come out in chunks. The only alternative would be to completely dismantle the shredder (not recommended).
Posted on Nov 17, 2009
Unit runs with nothing inserted into shredder
About 598,000 results (0.73 seconds) Search Results
    [PDF]Shredder Troubleshooting FAQ
    https://images-na.ssl-images-amazon.com/images/I/81GTHxKpz9S.pdf
    Make sure that the unit is securely plugged into a working outlet / socket. 2. If you have ... The shredder runs but it does not pull paper down. 1. Be sure the ... When ready to shred, be sure to insert material directly into the center area to start.
    [PDF]Instructions Manual
    https://images-na.ssl-images-amazon.com/images/I/71EUxqIkPNS.pdf
    you leave the shredder in the "Off" position whenever the shredder is ... To beginshredding, locate the switch on the unit and select the "Auto" mode (FIGURE 2). ...Your basic vegetable or cooking oil (nothing flammable ... a) While in "Auto" mode, the motor will not start running until paper is inserted into the feed slot. Set.
    General Shredder Troubleshooting - iThinkBlue
    store.ithinkblue.com/shredder-troubleshooting/
    Make sure that the unit is securely plugged into a working outlet / socket. ... While in "Auto" mode, the shredder will not run until paper is inserted into the middle ...
    [PDF]troubleshooting paper shredders - Ativa
Jan 31, 2016 | Shredder Office Equipment & Supplies
Only goes in reverse when paper is inserted
Shredders have three settings
Manual forward
Manual reverse
Automatic
Better shredders also have sensors that turn on when paper is inserted. It sounds as if your is in reverse and auto start.
Oct 22, 2015 | Office Equipment & Supplies
How do I fix the rollers that won't turn when paper is inserted in shredder?
That shredder is as weak as they come - it is probably a broken plastic part inside the mechanism. Recommend you throw it away and get the Amazon Basics shredder, your experience will be much better. Sorry.
Jan 16, 2015 | Royal Office Equipment & Supplies
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Paper won't shred
When the paper is inserted can you still see the cutting shafts turning....if not then take top cover off and chk...you most likely have damaged plastic gear in drive train.
Apr 20, 2010 | Adler Royal 85MX Shredder
Shredder will not
Andrew,
You have done all the right troubleshooting.
I would say the circuit board is toast.
Sep 17, 2009 | Office Depot Ativa DQ60M Shredder
Auto mode the blades continue to turn
Unplug it! Clean the optics in the center where paper is inserted. You can do this with a cotton swab. Check to make sure no paper has lodged itself in the infeed center. If no optics, then check to see if a metal arm that activates the machine isn't stuck in the on position. This will be in the center of where paper is inserted. This repair might require the cover to be removed. Remember, unplug the shredder.
Feb 23, 2009 | Office Depot Ativa DQ60M Shredder
Have a level 6, won't shred
Unplug the shredder. When you remove the cover carefully remove the auto start sensors. There is a little pushdown tab.Clean them with a soft cloth. A kleenex will be ok. Re-insert them, making sure they lock in place. Plug the shredder in an see if that solves your problem.
Sep 19, 2008 | Geha Primo 3900 HS Shredder
OfficeMax 0M96431 Shredder Logo
204 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
