Back to:
Tags:
Emerson TS1997 19
Optic block
posted by Cruizen1 on Jan 10, 2008
whats a optic block,whats there function,an how much does it cost?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 10, 2008
Not Rated (0)
sedonix
Rank:Guru Guru
Rating: 86%, 468 votes
Used in LCD and DLP type projection TV's to hold all the optical stuff that creates, focuses, and projects the image onto the screen. These TVs are much like a regular video projector except all folded up to fit it into the space of a TV. They are generally not repairable, are prone to get overheated, warping the plastic optical cavity housing and distorting the picture. Very expensive to replace as a result, usually over a $1000 and why you want to keep one of these TVs under warranty for its entire life.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on optic block:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
Emerson TS1997 19" TV
is this tv unable to connect to any kind of vcr or dvd...
how do i set the color it to dark and /i have no controler
Help! I bought a innovage jumbo universal remote,...
how do I get rid of it
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
