Question about Motorola Mobility RAZR V3
Can a motorazrv3 be used as a dial up modem if so what are the sittings
Dial tone of my phone disappears whenever i switch on my computer and my d link dial up modem can't find dial tone. What should i do?
Disconnect the telephone-cable from the computer's modem.
Does your telephone regain the dial-tone?
If so, then replace the computer's modem -- it is going "off-hook" as soon as you turn on the computer, not just when you try to use the modem to open a dial-up session.
Sep 27, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
We are unable to have highspeed internet and have to have dial up but there is no modem on the laptop I have. How do I get a modem downloaded into my laptop to use the dial up at my home?
Hi Guest,
You cannot download a modem for dial-up internet as you do not have an rj11 phone jack on your laptop so you need something like this that is a dial up modem that plugs into your usb socket.
http://www.amazon.co.uk/TRIXES-External-Voice-Modem-Windows/dp/B005C4680A/ref=sr_1_1?s=computers&ie=UTF8&qid=1372023578&sr=1-1&keywords=dial+up+modem
Jul 14, 2010 | Acer (91.AB193.021) Modem
How do get a dial tone when using the data fax modem?
try bypassing their modem and see if you get a dial tone,,,if you do then you know thats where the problem is
Feb 26, 2009 | Computers & Internet
Do I need a modem card?
If you will be using a DIAL-UP internet for that computer, you really need a PCI dial modem for it and it will come with a setup CD that you need to run to that computer so all software will be installed for that dial up modem and that should be it....
Jan 29, 2009 | Dell (313-3460) Cable Modem (W8378)
Missing modem
what is XE3 circa 2002, 15 years young. wow.
XP is now 3 years dead, at microsoft.
why not at least upgrade to Win7. be wise to do that.
XP must have SP3, if not it will fail, and even with it it fail.
lots of USB devices for example will fail. here.
dial up, you dont run DSL.
ive not see dial up in 20 years. why dial up.?
if compelled to use dial up, you need a modem that XP understands
most of them it does not. nor will it ever,
there are 2 classes of modem. (DIAL up to POTS)
1: software modem (99% software, and a box) they SUX. all do.
2: hardware modem, best is USB. by
and A good dial up program,. windows dial up software stinks.
https://www.cdw.com/shop/products/Hayes-ACCURA-World-Approved-V.92-56K-External-USB-Mini-Modem/1651998.aspx
i see this is HP supported (was) modem
Agere systems soft PCI
it needs the HP.com driver to run that modem
does the number you dial buy hand (using a POTS phone)
dial up and answer and squeal? if not its hopeless that number
you need to pay for superscription service, and with a pass word.
LIKE HERE
http://www.earthlink.net/dialup/
THE PROBLEM IS HP NO LONGER SUPPORTS YOUR PC
SO THERE ARE NO DRIVERS. now.
why not get 10 year or newer PC, or get DSL to home
or cable modem with only 1 channel active, (slow like dialup)
for cheap. (im using 16channel now, as i type)
or buy a new modem and connect it and use the new modems
disk to install a nice dialer for you.
but finding one is not easy now.
the best modems, are Hayes, there hardware modems are like rock. i used them back in the ARPnet days and on amocat.
Apr 20, 2017 | HP XE3 SYSTEM BOARD WITH MODEM & LAN HP...
When I tried to go online my Compaq Presario SR110nx gave error 680
Error 680--- No dial tone
A) Test modem by dialling a number through HyperTerminal or phone dialler. This will test the Modem without using Dialup Networking.
B) Make sure you are using the correct and/or original cable. Some modems used specific wiring which is not compatible with standard modem cables.
C) Check that you phone line is working with a normal phone.
D) Make sure the phone line you are trying to dial on is not a non-standard line, this can cause problems also.
E) If all the above are OK then get a new modem or test in a different location.
Sep 01, 2008 | HP Computers & Internet
New computer running slow
if you are using dial up, you shud not have a modem.. modem is just for DSL connection
if you have a modem probably you are using a DSL connection
DEFINITION:
dial up - connection using a phone line with internet connection; cannot use fone while on internet
DSL/modem- connection using a modem plugged in with computer and fone line; able to use fone even when on internet.
Jul 10, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Motorola Mobility RAZR V3 Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
