Question about Frigidaire ATF6000ES Front Load Washer
Hello i just bought a new washer and got it out of the box last night . put 1 load in and after a while the washer jumps all over the place . fixed the legs to leavel doesnt help any thing else i can do
  • 1,305 Answers
Making sure that all 4 legs are SOLID on the flooring is criticical on these newer machines. Here is an excerpt from the install guide: "Leveling the Washer
Excessive noise and vibration can be prevented by properly leveling the washer.
1. For free standing installation and with the washer in it’s final position, place a level on top of the washer. Adjust the leveling legs so the washer is level front-to-rear and side-to-side, and stable corner-to-corner.
Press down on alternate corners and sides and feel for the slightest movement. Adjust the appropriate leg so the washer is SOLID on the floor on ALL four legs. Keep the leveling leg extension at a minimum for best performance of the washer. "
Here are a few other things to check:
1. Make sure you have average sized loads- not just a single item or too many. I've seen machines that have one towel in them dance all over the laundry room... one wet item can really throw the machine off balance all by itself... make sure there's a few similar items in the machine.
2. If you overload it, cram it to the gills, it will struggle to spin all the water out as well.
3. Also if none of this helps, watch the floor area as the machine spins. If you notice the floor isn't solid enough, it may be flexing and need some reinforcement... this usually isn't the case,
Posted on Nov 17, 2009
    Genius:
  • Frigidaire Master
  • 1,460 Answers
Trust the transit brackets have been removed?
Model #110.88752793. Not sure of age as it came with mobile home. I have used it daily for 1 1/2 years. Dryer works extremely well and washer did also until last night. Two washes with the same problem. On...
Run the washer without a load in it. Open the lid when it goes to agitate and see if it is actually agitating by hold the lid switch down
with a small screwdriver or a pen. You may hear the grinding noise while it's agitating, just not as pronounced. You most likely just need the "motor coupling" on the unit.
Post back your results.
Sep 26, 2011 | Kenmore 88752 Top Load Stacked Washer /...
I have a 1989 Volvo 740 gle sedan i bought a battery but it will not hold charge, but it did last me 6 hours but sadly when night time came around and i turned on the head lights the car died. i got i jump...
Hello, The alternator is responsible for charging the battery. From what you have explained it sounds like a bad alternator. I may go to the person you bought the car from and ask to see documentation such as a receipt of purchase of the alternator. If he bought a new or refurbished alternator then it is defective and the place it was bought from should refund or replace it. If he got one used off another car or perhaps a junk yard then "new" can be an overstatement.
Mar 17, 2011 | 1987 Volvo 740
I have a WD 1049C front load washing machine and behind the front seal there appears to be a mould buildup. How can we clean this area?
you would need to take out the whole drum assm....in other words you will need to dismantle the whole unit.....first thing first get lysol aerosol spray and spray around were there is mold.....i would take the unit outside and then spray it.....becuase once the mold have been disturbed it will find another place to live on......next u will need to use front load HE detergent......when you wash your laundry....start with the cold water clothes first then the last loads use hot water so it will wash clothes and disinfect at the same times...
lastly after all luandry have been washed ........open washer door over night so it can air out.......if not opening it at all the water and detergent that sits over night can cuase mold buildup and foul odors.....the gaskets are air tight and can not evaporate when door is closed.....
if your house has a/c i would put a fan in front of the washer over night..............
a feed back would be good if this helps anybody.....
my opinion........
the older top load washers are better..............
Apr 11, 2010 | LG WD-1045FH Front Load Washer
On a flat floor but bangs and crashes when spinnig. Also the drum wobbles.
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire Affinity ATF7000ES Front Load Washer Error Message
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the mains. You have to look for screws below the front kick-panel, you can raise the machine a bit to gain access to the screws, the panel comes down & out. You may find a drain hose here, on left, drain off the excess water. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. You can pass it into a large plastic bag. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Pl rate me nice for the free help!
Apr 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
During washing the kenmore 70 series washer squeals
Re-check the motor coupler.
If it was not seated flush on both post it will bind and squeal.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
No lights or power comes on, door lock.repair man said control box so bought new one still no power,got 120 volt going in to box, (ghw9250ml0 = front load)
i think you brought the wrong board ,,i looked this up a night ago,,you need the power control board,,,im going to get the part number,,and you match it to the box or invoice,,,
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore stackable
I just fixed this same problem last weekend. First, you want to look under the machine. Get someone to help you tilt the machine until you can see the three big springs underneath the washer.
On my machine, it turned out that one or two of the the big springs that hold up the tub were either broken, or had jumped out of their sockets. Go to the parts depart of the Sears website, and give them a call. Don't bother with searching for your model number, because it doesn't usually work in the search.
You may need to also replace the bottom tray if the threads holding the springs down are stripped. Either that, or you can get some 1/2" nuts to hold them in place after you get the new ones. The set of three springs costs about $80-$90 dollars (not including shipping). The set also has excellent instructions on how to replace the springs. Took me about 2 hours to do by myself. If you're handy around basic mechanics, then I would highly suggest doing this yourself. But check the springs first before you go ordering them.
Dec 31, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Top Load Maytag Neptune Washer
hello i am a appliance repair man. do you was a lot of sandy cloths? what is happened is your seals are bad on the washer. i bet the sales men told you when you bought it that you could fill it plum full. its not true. i have seen this machine in and out of my shop so many times its not funny. by the way if you do fix it please put a surge protector on your machine. trust me it will save you more headaches. if you have any more questions feel free to email me at weltmister1234@yahoo.com. next time you buy an appliance call a repair man and ask them what kind of problems that the appliance has first.
Nov 08, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Old whirlpool washing machine won't run.
Need the Model # from the unit open the lid if it is a top load look at rear where lid closes to on the rim
Oct 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
131 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
