Question about McCulloch 16" Electric Hedge Trimmer 2.6A
Thicker twigs jam hedgetrimmer and strip teeth from main gear-where find schematic/parts diagram 16 inch mcculloch electric?
2 Suggested Answers
  • 491 Answers
SOURCE: what is the petrol / OIL MIX FOR MCCULLOCH M542P
Most newer 2 stroke engines run on 1 part oil to 50 parts gas.
Use a high quality 2 stroke oil mixed into the gas.
Posted on Sep 04, 2009
I am looking for a Pdf manual download for an old electric chainsaw McCulloch model 40004006 16 inch.
http://www.searspartsdirect.com/model-number/eagerbeaver400s16/0684/1503210.html
May 30, 2016 | McCulloch Garden
McCulloch Chainsaw Gear Drive Sprocket stripped
Ken's Repair Have 9 totes of parts for McCulloch saw Weed eater Modal # and Serial # Please
Feb 24, 2014 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Have a problem with my electrical Kraftsman chain saw, the engine is running and the chain is rotating, but when I put it against the tree for cut, the chain will stop rotate bot the engine is still...
The main drive gear is slipping. This is caused by etiher worn teeth or worn bearings. If you pass the model number I can show you a diagram of where to look and what part or parts that have most likely failed. The drive gear is the weakest link but the motor can be shifting in the housing away from the drive gear. It only takes a bit less than 1/8 inch side play. The model number will be similar to this 358.341160
Most likely it is item 26 of this diagram:
http://c.searspartsdirect.com/lis_png/PLDM/P0101241-00001.png
This example is for model 358.381160
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358341160/0247/1503210/P0101241/00001?blt=06&prst=&shdMod=
Thanks for choosing FixYa, Kelly
Sep 13, 2011 | Craftsman 16" Electric Chainsaw Chain Saw...
I have a McCullock 14" electric chainsaw model
www.erplacementparts.com they have almost eveything. breakdown diagrams too.
Jul 09, 2011 | McCulloch Garden
My older model Hobart n50 mixer stopped working. The motor is running but three teeth on the fiber gear were broken off from the main gear in the transmission. While removing some of the grease, I found...
The best solution I can give you is to become a member at the Hobart Corp. website and use there schematics to find where the pin goes. It is free to use the parts catologues have a parts blowup.
Follow the link below:
https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FsalesZ2Fredirect.aspx&reason=2&formdir=2
Thank you for using FixYa, I hope this helps.
Jan 19, 2011 | Hobart N50 Stand Mixer
Remington chain saw, electric: jammed and now the
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "M30016US" into the "Model #:" window, then clicked search.
  • Click the M30016US - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" think you want item 18, 113004-01, Internal Gear
  • Click the 113004-01 - USE REPLACEMENT PART # 122513-01 "View Part" link.
Results follow:
Part #: 122513-01 Price: $24.00
Description: KIT, INTERNAL GEAR (MOD) 747 B/O
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Nov 10, 2009 | Remington M30016US 16" 3.0 Peak Hp Modular...
Internal gear slipping ,seems like rart of gear
you may be able to fix your problem by tightening up the chain a bit more. other wise, you may have to have that gear replaced because as you indicate it may have had it's teeth worn down. i would begin by tightening the chain.
Aug 14, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Gears on my Mcculloch Chester 510 Hedgetrimmer may
The problem was with a stripped gear on a mcculloch hedge trimmer. I chucked it on the scrap heap and am borrowing my father-in-law's machine until I have time to shop for a new trimmer. Problem solved, but sadly not owing to your service this time.
Jun 16, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Jun 21, 2007 | Royal 150MX Cross-Cut Shredder
McCulloch 16" Electric Hedge Trimmer 2.6A Logo
201 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
