Question about Compaq Presario 5000 PC Desktop
In my desktop computer voltage drop after 10 sec.
    President:
  • 995 Answers
Check your power supply if it is working properly. Try using another power supply for your computer.
Posted on Nov 17, 2009
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Voltage drop. When in parked I rev up the engine, when it comes down, the voltage drops from 14 to 10, for about 5 secs. I think the truck will cut off but it immediately comes back up to 14.
If the alternator is weak, and you have accessories like the headlights or blower motor running, and the RPM drops below 600, the voltage could be below 12. It would depend on the load, RPM, and several other factors.
Feb 12, 2014 | 2000 GMC Yukon XL
I recently turned on my hp 6500 f desktop computer and it gave like a 15 sec beep and stops for 10 sec and keeps doing itcontiniously don't know muchabout computers need help
The motherboard is detecting some "fault":
* RAM not properly "seated" in its socket
* video-card not properly "seated" in its socket
* "bad" RAM (that is not working correctly)
* overheating (fans inside the case no longer working)
Take your computer to a qualified technician, at any computer-store, for professional diagnosis & repair.
Nov 15, 2010 | Computers & Internet
12RES GEN.NAT.GAS FAILS TO START BY STRT BTTN AND TRNSFR SW
If the succession is 3-5 sec crank - 3-10 sec pause, it is OK, but the cranking is not successful (the reason should be investigated).
If the succession is more rapid 1 - 2 sec you may have bad PCB control.
Jun 03, 2010 | Kohler 12 kW Emergency Power System -...
MAY NEW ALTERNATOR PUTS OUT 14 VOLTS WHEN I START THE DIESEL 5.9
the voltage regulator is in the computer,check you battery with volt meter with engine off it should say 12volts then check it again with engine running and it should say 14-15 volts. if not the you will have to take it to a dealer to check the computer,hope this will help you!!!
Apr 19, 2010 | 2002 Dodge Ram 3500 Truck
Liberty will not turn over
Doesn't that jeep have an on board anti theft system that shuts of power to the startee and the fuel injectors. Im pretty sure it does thats where to start sometimes just turn the key to the on position for 30 sec. To 60 sec then crank the engine if that doesnt work turn off at least 10 sec try again tirn to on position without cranking motor for at least 30 sec then try cranking
Sep 20, 2017 | 2003 Jeep Liberty
CHANGED CPU SPEED ON MOTHER BOARD "FOXCONN 661M08-FX-6LS" AND NOW KEEPS BEEPING. CAN I RESET MOTHER BOARD. THANX
Yes you can reset it, just make sure you unplug the computer before doing it...
Open the left sidepanel and either look for the clear cmos jumper and switch it to the other pin for 10 secs, or you can remove the cmos battery for 10 secs
Sep 19, 2008 | Computers & Internet
My computer shuts down after 3 secs
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power.
if not solve the problem try to examine the your system power supply.
Dec 11, 2007 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
