Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
GE ZONELINE AC , PARTS FOR TEMPERATURE UNIT AND MODE UNIT
  • Anonymous Mar 23, 2014
    Our unit has started randomly coming on when in the off position. When that happens the only way to make it stop running is to unplug the unit. What is causing this?
  • 80 Answers
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Posted on Jan 14, 2008
6ya staff
SOURCE:
Heater not working just blowing cool air
hit the easy button
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 08, 2018 | GE Heating & Cooling
Heating and air unit electrical manual
http://www.geappliances.com/products/introductions/zoneline/literature.htm
Aug 20, 2014 | GE Zoneline In Wall Ptac Unit Air...
Condenser won't kick on, and is hot. Fan works? What's should I do?
Check whether the AC is on fan mode. There are two mode for this type. FAN and AC mode. Put it to AC mode and set the temperature. Solved!! :)
If it doesn't work, call the AC repair guy.
1) Either there will be error with the capacitor circuit which triggers the condenser.
2) there is an issue with your condenser and the circuit.
This is a small repair.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
Sanyo PTAC model STB0823H1 elec. heating element
Try 1st link for Support Request, 2nd link enter zip code
http://shop.panasonic.com/hvac/how-to-buy/distributor-locator.dot
Dec 12, 2013 | GE Zoneline Deluxe Series Cooling &...
I have 3 Fujitsu heat / cooling multi split ductless units connected to one rooftop unit. Only in heating mode and only coming from the same indoor unit is a loud almost screeching/vibration sound. It can...
If it happens in heat it must happen in cooling. The indoor unit has nothing to do with if it's heating or cooling. You likely have 2 moving parts in the machine, the blower wheel and the swing fins. Turn swing option off, eliminate that. You get the rest...
Jun 04, 2017 | GE Zoneline AZ38H12DAD Split System Air...
I have a AZ38H15DADM1 that works fine in heat mode and in AC mode it works great until it reaches the temp it thinks it should be, then it cuts off and never cuts back on without me physically turning the...
When setpoint is reach unit would shut off .
If you put the fan to the ON position it would run all the time and ac would cycle on and off depends on the temperature
Feb 12, 2018 | GE Zoneline AZ38H12DAD Split System Air...
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Nov 28, 2007 | GE Zoneline AZ55H09D Air Conditioner
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
279 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
ray gallant
Todd B
J Rosado
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
