Acer Extensa 5620 HD and LCD screen problems
I just got a brand new Acer Extensa 5620.
Out of the box, the computer doesn't boot up. Its a computer set up for Vista, so I got a Vista install disc and it began the install process. 1st issue it hits is that when Vista needs to be pointed to a storage device for installation, the computer says no device drivers found for the HD. The HD, according to BIOS info screen is a Toshiba MK2035GSS-S1. I have found no solution from the Toshiba site or Acer site.
#2 issue is that the LCD screen intermittenly washes out colors into greens and reds and get hazy as though a double image is occuring on the screen. If I were to hit the machine softly...the screen fixes. Its acting as though something is loose, but I'm not sure how to trouble shoot this issue.
Am I doomed...or can this be fixed easily...hopefully by me?
  • sincap2 Jan 10, 2008
    Thanks for the info. The screen was the issue bugging me the most. I can easily replace the HD on my own if need be. At this point, I hope Acer responds to my service request in a timely fashion.
    Sergeant:
    Champion:
  • 317 Answers
Unfortunately, the only way to repair the screen, is to send the computer back to acer. The prolem, is that the diode that controls one of the RGB Channels is broken, and since there are a million of these the size of a pin tip, it is extremely hard. As for the vista install problem, it could be a bad hard drive, try installing a new one, and if that doesn't work try finding the drivers it needs, and installing them somehow.
Posted on Jan 10, 2008
Acer Extensa 5620 notebook unable to power on
Have you tried using a different adapter? It might be that the power adapter is defective. If it isnt then you may need to replace your motherboard. And with regards to your hard drive, there are third party technicians who caters to retrieving data from drives. They may try to use that drive to a different computer to retrieve your files.
Jul 18, 2010 | Acer Extensa 5620 Notebook PC
Acer extensa 5620 p[owers up to boot stops then reboots three times then stops blank screen through out procedure changed hard drive to no effect.?
You boot files could be damaged. Try booting up in Safe mode. To boot in to Safe Mode. Press the F8 key while booting up and you will get a list of booting options. Choose the Safe mode. If you are able to boot up in Safe mode, then the next normal boot should solve the issue.
Mar 19, 2010 | Acer Extensa 5620-4020 Notebook
Acer extensa 5620 laptop will not boot uo
Then you can check 2 things to see if the machine will boot. If not, then you'll need to get it repaired. FYI, I repair Acers.
Step 1 - remove the battery and the A/C adapter from the back of the computer for about 2 minutes. Replace the battery and the adapter and try to start the machine. If that doesn't work, go to step 2.
Step 2 - Check that the A/C adapter is getting power and the LED for battery charging on the front of the computer lights. You can check the voltage from the power supply with a volt meter, if you have one -- it should read around 18-19 volts. If either of these steps don't work, you'll need to get it looked at.
Problems could be with the power supply, motherboard, power switch, CPU or something else that only time and expertise could properly track down.
Jan 08, 2010 | Acer Extensa 5620-4020 Notebook
Acer Aspire screen in Extensa
Hi, yes they should change over no problems as long as power and inverter are same or replaced, follow these diagrams or check for more details,
http://www.laptoprepair101.com/laptop/2006/07/08/notebook-display-diagram/
Best of Luck,
Terry
Dec 21, 2009 | Acer Extensa 5620 Notebook PC
Acer extensa 5620 ,the LCD backlight problem
Sounds like you need a new lcd screen. If you're getting an image on the external monitor, that means the video is good. Hopefully you don't have your screen brightness turned all the way off to make the screen black.
Mar 02, 2018 | Acer Computers & Internet
Acer 5620-6266 notebook will not boot--Media Test failure
Open BIOS and configure your boot devices priority. First boot device should be the hdd. Also check if the laptops see the hard disk, i think your hard disk have a problem and thats why laptop wants to boot from network.
Jul 18, 2009 | Acer Extensa 5620 Notebook PC
The monitor is black but the computer functions correctly. Acer Extensa 5620 laptop.
You should replace your "backlight" in your lcd, or if you have the money you need to replace your entire lcd. This problem it is because your inverter couldnot turn on your backlight wich it is burn or broken
Apr 20, 2009 | Acer Extensa 5620 Notebook PC
Acer extensa 5620 it shutdown but stiil power remains on.
please install "Avast antivirus" after installing the antivirus, system want to restart then you must restart your sytem , then the system scan all drives for viruses at boot time,if any virus is found the system will want to delete it by pressing 2 and it will delete all viruses from your system, then you must repair your operating system with xp bootable CD , after repair you must install your system drivers......... and then your problem become solve
Jan 25, 2009 | Acer Extensa 4620 Notebook
ACER extensa 5620 drivers
Pls. visit the link http://tinyurl.com/3vs5c2 which will help you to download the driver for the computer.
Sep 22, 2008 | Acer Extensa 5620-6119 Notebook
Computers & Internet Logo
861 people viewed this question
Alun Cox
David Payne
David Payne
