Water running from the back of my air conditioner down the wall it looks like it is actually coming from the back of the unit
  • 534 Answers
You have a clogged condensation drain. Easiest repair is to find where the drain exits the house usually by the outside a/c unit. It will be a white pvc pipe that is sticking out of the side of the house. If this is found you can use a wet/dry vac and place it on the end of this pipe and evacuate the water and debris from there. If the pipe isn't found you need to go to the furnance and find the white pvc pie coming out from the furnance and using a pvc cutter cut the pipe at that point and use the wet/dry vac at that point. Make sure you vacumm out both directions since you dont know where the blockage is. To repair the cut pipe use a pvc collar and you will not need to glue this collar back since there isn't any pressure in the pipe and it can be used again should you have the same problem later. Go to a neighborhood home repair shop and explain what you need to do and they will assist you with parts and instructions. Good luck on your repairs hope this helped
Dave
Posted on Nov 17, 2009
Testimonial: "thanks so much for your advice it was very helpful"
    Scholar:
  • 111 Answers
Turn the unit power off at the disconnect or breaker for the air handler.
Remove the panels from the front of the unit.
Get a flashlight and look down where the coil is located, usually towards the bottom of the unit, and look inside the pan that collects the water.
Verify that its not full of water, If it is then you will want to find the drain line that is outside and connect a wet vac to the drain line and remove the water from the line.
Keep the vacuum running and go back to the air handler and make sure you can hear the air sound from the line being cleaned from the vacuum.
If you do, great. Then find something to put some water into the pan so you can flush out any extra build up that may be in the pan (algie,Rust, ect) repeat until clean. Pour a little vinegar in the pan as well to help reduce algae build up.
Also make sure that the pan is not cracked anywhere at that the drain lines are connected tightly to the pan.
If you have access, remove the filter and inspect the lower part of the evaporator coils and make sure they are clean, if there not that could cause excess water to drain down instead of in the pan.
If you have a level make sure the unit itself is level and not leaning to far to spill water out of the back of the unit.
Good Luck.
FlaTech
Thank you for using FixYa!
    President:
  • 1,515 Answers
Hi, it sounds to me like you have a ductless split system, and water is over flowing and running down the wall.Causes for this could be, a dirty filtering media and or evaporator coil dirty causing the unit to ice up some, and the drain not being able to keep up.Several things can cause this. Condensation at the indoor coil is normal, but not if it is building and running over.What needs to be done, depending on how high up they put the indoor unit, is to get the proper size ladder, and remove the cover to expose the filter and coil.You can wash the filter in warm water if it is of foam. Look the coil over to see how dirty it appears, for instance if you can peel a sheet of build up off, than you know it was icing up and restricting air flow.Just at the bottom of the coil, you will see a drain trough and should be able to locate the drain hose connection. This tray must be cleaned out and try pouring water slowly in the area of the drain to clear it. Lay something down to protect you're floors and so on, but this has to be cleaned out so that the normal condensation can drain. Good Luck, and be safe on the ladder, Sincerely,
Shastalaker7
Why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by...
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
Jul 04, 2011 | Friedrich Heating & Cooling
Water runs down interior wall into room
The unit has one of two problems...
either the unit is tipped towards the inside or the holes in the back corners that drain the unit are plugged up...
heatman101
Sep 27, 2010 | Haier hwr10xc6 Air Conditioner
Leaking water
Is this a car? a home window unit?If it is a home window unit,take the air conditioner out of the window/wall,and take it out side and wash the unit out with water hose.Be careful not to bend the fins over on the coils,this will restrict air flow.If the coils are nasty,use a product called purple power.You can purchase this at auto parts.Use this purple power full strength in a spray bottle and spray all over the coils,and let it set for about 10 minutes,and rinse.Repeat as necessary .Fan the water hose nozzle out so not to flatten the fins on the coils.When you put ac unit back in wall/window,make sure the ac unit has a tilt on it leaning outward,and down,to assure the water drains outward on the ground. If the ac unit your talking about is in a car,you will have to get under the car,with a flash light and look up under the firewall.There will be a tube,or a plastic spout coming out of the ac box,for drainage of condensation.Take a skinney wire,and run it in ,and out of the tube or spout until the water starts pouring out like a waterfall.If it does not unclog,use air pressure.I hope this helps,let me know if it does.
Aug 27, 2009 | Heating & Cooling
Dripping air conditoner
The "drip pan" is actually the entire base srround of the unit. There are two critical things you must confirm 1) is the unit angled back to the outside(you need water to flow away from the inside) and 2) there may be a plug/obstruction in the outer casing where the water is intended to drain from. You should check to see if either or both of these conditions exsist.
Aug 19, 2009 | Heating & Cooling
Just purchased a 15000 btu 110 Frigidaire window unit and we love it. However, since the rear of the AC is actually on the back porch, the water from the AC runs down the wall and on to the floor. We could...
window units slide into an outside frame section
there is a hose attachment area at the back of the ac unit proper that a hose can be attached to
and there should be a section in the frame that allows the hose to be fitted to that ac unit proper
the unit should be mounted so that it actually slopes slightly down at the rear so water can collect at that drain point
there are adaptors that should have come in the packing box for hose attachment
if not, many people use white poly piping or electrical conduit with suitable elbows to collect the water at the hole and pipe it back to the wall into a bucket and the collected water used to water plants and gardens
May 02, 2017 | Frigidaire FAC126P1 wall/window Air...
Where does the water come out of a Daewoo DWB-126CH Air Condition
I am not sure what this unit looks like.Is suppose to be like through the wall unit?Or is this one of those new styles that sit on the floor?If so then you will need to run a drain from it.
Apr 05, 2009 | Daewoo Heating & Cooling
Wall unit leaking water in the front
The problem is in the lines that run from indoor to outdoor unit.
You need to make sure all lines are slightly sloping towards outdoor unit
Jul 20, 2008 | Friedrich QStar SQ06J10 Air Conditioner
GE Portable Airconditioner - Model APN10AA Serial # GG509122
Ours was leaking water. After taking the covers off,cleaning it,and draining all the water out, I started getting the same problem with the light coming on every 7 minutes. I actually added some water to the system till it was too full and then drained it out through the plug. The light still came on every 7 minutes until I turned the unit off and then unplugged it for a few minutes. I plugged it back in, turned it on and reset the temperature. It seemed to reset itself and kept running normally. BB
Aug 07, 2007 | GE APN10AA Portable Air Conditioner
Heating & Cooling Logo
270 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
