Question about Simmons Outdoor AETEC 2.8-10x 44mm WA (2.8-10x44 mm)
My scope has moisture in it. How can I get it out
My rifle scope has moisture in it. How can I get it out
    Problem Solver:
  • 18 Answers
At the factory they fill the scope with nitrigon to keep them from fogging once it is gone the only way to fix it is send it back to the factory. Good luck.
Posted on Mar 11, 2010
Cross hair broken on my B S A mil dot 4-16 x 40 scope will any gun shop be able to repair
Yes, more than likely.
The scope just needs to be disassembled and the crosshair flange repaired or replaced.
A dealer should be able to order the part or at least fit one similar enough to work.
The trick is not to allow any moisture into the scope's internal cavity during the repair.
Mar 06, 2011 | BSA 4-16X40mm Mil-Dot Rifle Scope - ...
My scope keeps getting fog and moisture, what do i do
in short,,,throw it away? the rubber "O" rings have failed and are letting in water,,,,its had it,
Nov 27, 2010 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
1. HOW TO READ SCALING OF SCOPE.? 2. What is
You have not provided enough information for us to help you. What type of rifle? What do you mean by scaling?
With the scope on 3 power you should be able to sight it in at 25 meters. Going to a higher magnification may cause blurring at that distance.
You also may have mounting problems that are causing the scope to move around when you shoot. Your rifle may be fine.
Oct 09, 2010 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Moisture in a rifle scope
Lay your scope in the sun in the window for a few days, or set it on a heat source, low heat, like a light bulb for a week,, try and cook it out, it got in there, it might come out. No guarantees. Hope this helps.
Mar 25, 2010 | Optics
Rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Dec 03, 2009 | Optics
Got moisture in scope and it is fogged up
take it into a camera shop, they will have the tool,, but if you undo the scope it will need to be regased again the "o"ring seals have worn out or broken and thats how water got into it,, it also let the nitrogen out of it,,,if its a cheepy scope buy a new one,,,
what i mean by a cheepy is less than £1000,,,,
Nov 16, 2009 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Elevation won't go any higher
Take the rear ring off and put a shim UNDER the scope.A small piece of plastic from a blisterpack works well and is very stable.Cardboard or paper will swell with moisture and then shrink when it dries.Good Luck
Feb 09, 2009 | Optics
Simmons scope that will not stay on target
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Feb 06, 2009 | Dual Electronics 6-24x50 AOE DUAL...
Just bought used 8x32 swat not sure how to use it. are the win and elev numbers for shooting or just for siteing in rifle
They are for sighting in the rifle only.I know on TV the shooter reaches up and turns a knob.BOGUS! after sighting in the rifle, always replace the little caps because the scope is not sealed unless the caps are on.without the caps, moisture can penetrate the scope and fog the lenses.Good Luck
Dec 08, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Simmons Outdoor AETEC 2.8-10x 44mm WA (2.8-10x44 mm) Logo
342 people viewed this question
Top Simmons Outdoor Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jerry Kramer
Jerry Kramer
andrewcahoon
Are you a Simmons Outdoor Optic Expert? Answer questions, earn points and help others
