Question about Astoria Argenta AEP-2 Coffee Maker, Espresso Machine
Pump nt working proper.y
Pump nt working properly and after a while some time dont pump the water to the tank and get empty so we have to pump the water manualy.
    President:
  • 1,618 Answers
Check the auto level probe and box, also check the inlet solenoid, one of these three are not functioning.
Posted on Jan 26, 2010
My samsung sdc1a809 dryer always giving drain water. Althought the water tank is empty. Checked the draining pump working properly. Any ideas !??
The sensor or logic board could be defect, when the logic board thinks there is still water in the tank. I would look there.
Apr 13, 2015 | Samsung Washing Machines
The shampoo is dispensing too much shampoo, it is empty in no time
Hello There,
Is your machine use the water from the tank at all? If your machine use too much shampoo, my guess is it use less or no water at all. In this case the pump is sucking very little or nothing from the water tank and it does from the shampoo tank.
Please look the attached plumbing diagram. After you opened the unit up, you can follow the tubes and clean the system (solenoid valves but mostly the tubes those involved in the water tank circuit)
Good Luck with the repair!
Sorry, I wasn't able upload!
Sep 10, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Not spraying water and solution
Tanks may be empty or not properly seated.
-Fill up the bladder with hot water and the solution tank with proper cleaning liquid.
-Remove and reseat both tanks
Pump may dry, needed to prime.
-Turn "off" power wait for about minute turn "on" power and depress spray trigger.
Check and clean filter on the deck (under the clean water tank, a red slotted plastic screw)
If nothing works you have to open the deck cover and go into details: check the pump, its a 12V DC motor, the solenoid, its a valve which operates with 120V, the hoses for broken or pinched part, the diode bridge (creates about 12V DC for the pump if the vacuum motor is turned "on" and the secret fuse (3,15A under the heat-shrink series to the diode bridge, if this one goes, no power to the pump!)
Mar 09, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
My water pump has stopped pumping. Nothing happened, one minute it was working, the next minute it was not. The power to the pump is working, there is plenty of water in the tanks. Please help! I need
this happened me in the holiday house it was full of water and would,nt empty .i disconnected the hose at the pump and there was a dollar note stuck in the out let of the pump you could try this first before you call a service man
Nov 10, 2012 | Washing Machines
I have a utilitech convertable pump. It is used as a shallow well pump at the moment. It worked fine untill last week, the hot water tank went bad and we replaced the tank and all the above ground lines....
Hi mid_age_elf
Your problem is that your "water bound"...
Your water tank must have a cushion of air for the pressure switch to work properly.
Turn off your pump and drain about 1/3 of the water from your tank.
Once you have an "air cushion" the pump and switch will work properly.
You can also add air pressure using an air compressor and an air valve installed on the top of your water tank or maybe on the side or bottom of the tank.
You would put air into the tank until about 1/3 of the water is gone replaced with the air.
Once that is complete your problem will be solved.
Please take time to rate me
Bud
Oct 21, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Pump comes on shuts off then comes on shuts off
In other words, it is cycling quickly. Check your bladder tank for proper air pressure. You will have to shut the pump down and drain the tank to do this as the pressure in the bladder is set when the tank is empty, or nearly so, no pressure on it. Set air for a couple of lbs below the normal on point of the pressure switch. If you don't know what it is supposed to be, start at 28PSI, after pump is working, check system pressure while it is under load, meaning turn on the water and let it run and watch pressure gauge for when pump comes on. If no pressure gauge, install one as you need it to see if you system is working properly. It it isn't a bladder tank, just an older style tank, same thing, same procedure.
Sep 13, 2012 | Goulds Pumps J and JS Series Pump nozzle...
RE: R/O system. Model # PNRQ20FBL Serial # TM30938P This system was in our home when we purchased it in Aug, 2009. The home was less than a year old - so the system was...
is there a precharge of air in your tank. when empty of water th?re should be about 1 bar or 14psi of air. water must be able to empty from tank. pump air in until all water is gone. if unable to empty tank has failed. also if a pumped unit, when changing filters ensure all air is bled through pump before turning it on toprevent air locking inside pump
Feb 28, 2017 | General Electric Profile Smartwater Ultra...
Red x does not turn water does not aooear to release properly
repaired many of these!
most likely its the pump.. the pump is located down by the brush...its belt driven(make sure your belt is there and in good condition)
the heater is located in the handle area...you could remove the hoses and blow through one end...shouldnt be restricted..
other possibilities
  • bladder maybe empty
  • formula bottle maybe empty
  • tank may not be seated properly
  • tank filter maybe clogged
Oct 05, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
DH400P
I had a similar problem with the pump not working and the water flowing into the main drainage bucket instead. I had to disassemble the housing...not an easy project to reassemble...and found that the pump has its own smaller drainage tank with a float device, a pump pre-filter, the actual pump, then of course, more drainage tubes. The entire pump drainage system of components needed cleaned of accumulated, mucoid, slime! I cleaned the channel in which water flows into the pump's tank...located on the screen filter side of the dehumidifier. Then I moved to the other side of the dehumidifier and cleaned-out the entire pump drainage tank. Note that the pump's drainage tank only empties about 1/2 inch of water each time the pump activates. Thus, there is always alot of water in the pump's drainage tank. Thus, alot of time for slime to accumulate. Next, I cleaned off the float mechanism. I then cleaned-out the pump's pre-filter. Cleaning out the pump's pre-filter was paramount to the pump functioning properly and quietly! I checked that my pump was properly installed and NOT rubbing against its mounting so that it operated quietly. I added fresh water to the pump's tank several times to insure that the pump was working properly and that all slime was eliminated. Finally, I reassembled the housing...not an easy task! My pump now functions like new. All this work had to be done to insure proper function of the dehumidifier's pump system. My dehumidifier is only 11 months old. It is still covered by the one year warranty, but it is too expensive to ship the entire unit, as Delonghi requires you to do at your expense for them to fix it under warranty. You can be assured that I will check for future slime build-up to keep my dehumidifier functioning properly. The dehumidifier works great, it's just that it's high maintenance.
Jun 15, 2008 | DeLonghi DE400P Dehumidifier
Astoria Argenta AEP-2 Coffee Maker, Espresso Machine Logo
144 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
obsteiner
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
