Canon irc3220 error 246-0001
This error happened after replacing the imaging processing pcb.the imaging processing pcb came from a working machine.
  • Anonymous Mar 27, 2014
    Machine is not working properly. The image is not clear. Printed image is not clear
  • 287 Answers
Hello tech. I am scratching my knoggin since I can't find an error 246 in the service manual and the Canon website had no such reference. There is however an E248 which I believe is a "bingo" for your problem (but after 20 years of copier B.S. I never say never to undocumented error codes). So I will presume it is an E248 and here is why. E 248 means the ID stored on the EEPROM of the reader controller does not match the ID of the SRAM pcb. In fact there is an article on the Canon support center website I am viewing now regarding this.The only way to fix this problem (according to Canon) is to formally involve their Engineering group by way of contacting Canon support group and have them escalate the problem all the way to the engineering group.You know how anal Canon is. But again there is some question about the error codes. I truly wish I could be of more help......my heart ,mind and time are on YOUR side. Good Luck member of the "copier hell " brotherhood! :-) I'll clear a paper jam in your honor!
Posted on Jan 19, 2008
Canon IR1022iF what are the solution to system error code E197
From this link:
https://printcopy.info/?l=en&mod=erc&brand=Canon&model=iR1022&code=E197-0000
E197-0000
Description
Printer engine communication error
- Erroneous communication between the DC controller PCB and image processor PCB was detected.
Remedy
- Check the connectors of the DC controller PCB and image processor PCB. - Replace the DC controller PCB for normal connection. - Replace the image processor PCB.
Nov 03, 2017 | Canon Office Equipment & Supplies
A system error E197 has displayed on my canon iR1018 copier. how will i solve the error problem?
the error is E197-000 Printer engine communication error
processor PCB.
The part number for the DC controller PCB is FM2-8365-000.
Best regards,
Marius
Jul 29, 2016 | Canon CART303 Laser Toner - Genuine, Suits...
Error code e00747-221f for machine canon irc3580
Sorry to say this error is a main board fault and that will need to be replaced. Expensive!! the following is from the manual:
E747 Main controller PCB error (Image processing ASIC or memory control/communication control ASIC)
Dec 18, 2013 | Canon iRC3580
E351-0000
E351: Error PCB ECO. Communication error between the PCB and the PCBECO main driver during startup.
Turn off main power and check the main controller PCB (primary, secondary), thenturn the main power.
Check in the back of the machine the main controller PCB (Main) make goodconnection with the PCB ECO-ID: help with image processing.
Hoping this is helpful message ... GOOD LUCK
Apr 28, 2012 | Canon Office Equipment & Supplies
E315 in Canon 405 machine
E315 image data processing error, first clear the code in service mode/turn off and on the machine; check the HHD may faulty. If this error happens very offenly then change the PCB, also try deleting messages in the MAIL BOX and restart the copier.
May 03, 2011 | Canon imageRUNNER 400S Copier
The image is shifted on my canon irc3220, How do i fix it ?
you can collebrate the image on copier so that image will not sift.
Apr 07, 2011 | Canon Office Equipment & Supplies
Error: System Error E197.Please help us to solve the err.
what machine do you have
E197 Printer engine communication error
connection.
Sep 03, 2009 | Canon Office Equipment & Supplies
Canon iRC3220 can print but not copy....
try re-seating the Ribbon Connectors between the Reader Controller PCB, CCD Unit, and the Interface PCB found in the Reader Unit. You can also try reseating the SD-RAM DIMM's on the Main Controller PCB.
If message is still appears replace the Sub Main PCB (FG3-2855-000)
Aug 05, 2009 | Canon imageRUNNER C3200 Copier
What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
Product : imageRUNNER C2880 / C3380 Title : E025 sub code 0002
Problem :
The machine is giving an error code of E025 with a sub code of 0002 indicating an error with the cyan toner motor.
Solution :
Replace the Process Kit Relay PCB. Item 58 of the Hopper Assembly circled below, part number FM2-8266-000. NOTE: the service manual refers to this part as the Process Kit Relay PCB while the parts catalog calls it the Connecting PCB Unit.
getfile.asp?rid=24817
Apr 27, 2009 | Office Equipment & Supplies
Canon MF6500 Error Code E197
Error
E197 0000 is a Printer engine communication error.
A erroneous comm's error occured between the DC controller PCB and
Prnter needs servicing
Check cabling connections on theDC controller PCB and image
processor PCB.
If still same then you have to replace DC controller pcb.
If still fials then you have to replace the image processor pcb.
Aug 05, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
424 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
