Question about Denon AVR 2808Ci Receiver
I was playing music last nite,and the amp cut off,feeling hot,very hot,now when i restart it it just turns off,any info on it,its a denon 3808.it was up loud,but the sales guy said this is the system to buy if i like loud music,thanks steve
    Brigadier General:
  • 8,546 Answers
If it works again after cooling off, count yourself lucky and take a lesson from your experience. Don't try to heat the room with it.
Look around fixya and you will see hundreds of problems just like yours, but most of them didn't start with knowing it was too hot or expecting it to survive it. This may be something you can prevent in the future.
Dial it back a bit, plus make sure it has proper ventilation and isn't near other heat sources.
Posted on Nov 20, 2009
    President:
  • Denon Master
  • 1,114 Answers
First thing to do is disconnect all speaker wires at the receiver. Then turn the unit back on. If it still shuts down, the problem is in the receiver and it needs to be serviced. If it stays on, reconnect your speakers one by one at the receiver and test. If there is a problem with a wire or a speaker, when you turn it back on it will shut down. If this happens, then disconnect the wire at the speaker and test again making sure the ends do not touch. If it still stays on, check the speaker for a dead short with a meter. If you are not familiar how to do this, go to any shop and they will test it for free. Hope this helps. If you need further help, post a comment and I will be glad to help.
Posted on Nov 17, 2009
Denon DCM-370/270 - issue playing CD's. A CD will
I would replace the audio cable from the CD player to the Denon amp, a long shot, if you have other devices hooked to the amp and plays fine, the problem will be in the CD player. However! if all sound sources have the same problem, the issue is with the Denon unit.
Mar 09, 2012 | Denon Audio Players & Recorders
My Fender deluxe VM soound started cutting out on me last nite-I narrowed it down to the actual amp-outside gig and very hot and humid. Amp is less than a year old-anyideas? tube problem?
Inout connectors are often broken by tripping overr cables resulting in intermittent operation. Wiggle plug and then each pot to see if anything shows itself. Circuit board cracks and broken solder joints are suspect as well.
Jul 24, 2011 | Fender Deluxe VM Tube Amplifier
Hi, how can i hook up a wireless 5.1 headphone to a denon avr-3808 using an optical connection. I can't find any optical output port on the denon amplifier.
My manual shows two optical outputs labeled "2 (DVR)" and "3 (VCR)" at the upper right of the rear panel.
It's unclear what will appear there when playing any particular analog source.
Feb 26, 2011 | Denon AVR 3808Ci Receiver
I need a Denon AVR-3808 Service Manual
try doing a google search for avr 3808 manual
also try going to denon.com if you need a hardcopy call denon tell them to send you one.
Feb 18, 2010 | Denon AVR 3808Ci Receiver
Hello, I just hooked up our new PS3 Game system to our Denon 2803. Was happily playing it when it cut out on me after about 30 mins of playing. Turned the volume down to see if I was overloadingit but it...
looks like you are overheating it let it cool down for at least 20 min. and then when you use it just lower the volume, after that it should give you no more troble
Dec 18, 2009 | Denon AVR-2803 Receiver
Denon ASD-3w ipod dock not being recognized by denon 3808
I successfully connected the ASD-3W to the Denon 3808CI using the supplied AV/Control cables (dock control, L & R audio, S-video). I used the video and audio input connectors marked VCR (iPod) on the 3808CI and used the default settings. I used the connector marked Dock Control for the control cable. These VCR (iPod) connectors are different than the input connectors marked VCR. I turned the source selector to VCR/iPod Stereo and operated the GUI using the ASD-3W remote control. I was able to play music and video.
Nov 16, 2008 | Denon ASD3W IPod Networking Dock Docking...
Updates
mr rusty
you might try here for more info on the demon updates there you find the req links ,
Denon 3808/4308/5308 Firmware Tracking Thread - AVS Forum
hope this some help to you.
riz.
Aug 07, 2008 | Denon AVR 3808Ci Receiver
Denon avr-5600 protection circuit.
My AVR 5600 has worked flawlessly for nearly 9 years!
Suddenly, when trying to play music (DVD or CD) through my LS32's (JBLPro), once I achieve higher volume, the receiver cuts off.... Using a Symetrex mixer, NO OVERLOAD light on the Denon, it simply cuts off!
Re-cut all the wire connectors... TV movies (5.1) work great at normal listening volumes.... but tonight, when cranking up music, the receiver simply cut off. Blinking light...
HELP
forfrance@hotmail.com
Apr 12, 2008 | Denon Audio Players & Recorders
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Denon AVR 2808Ci Receiver Logo
149 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
