Adding ram to presario v5000
I want to add ram to my computer but I can't get into it. I took every screw out of the bottom and couldn't get it apart. Any ideas?
  • fiend1182 Jan 10, 2008
    thanks, i figured it out right after i posted the question
  • 1,067 Answers
Should be under panel simple 1 screw on back pop it up with flat head
Posted on Jan 10, 2008
Compaq presario v5000 won't stay
sounds like overheating , probably due to the cpu or gpu fan/heatsing loosing contact, even a little knock could have caused this
Jul 16, 2010 | Compaq Presario Notebook
Adding RAM memory
Usually they are both in the same spot: inside a removable panel on the bottom of the laptop. One is just above the other. If you only find one slot on the bottom of the laptop, then the other one is usually just under the keyboard. Some keyboards are easier to remove than others. Sometimes there are screws going thru the bottom of the laptop casing that hold the keyboard in, as well as some small screws going along the top of the keyboard; which are usually covered up by the molding with the power button on it. There could be several screws that you have to remove in order to get the molding and keyboard removed. Be delicate with the ribbon cables. They can be expensive to replace, and be sure to remember exactly where all your screws go back into.
Apr 24, 2010 | Compaq Presario R3000 Notebook
Trying to install memory on laptop not sure where it goes
Hey! Generally for RAM there is a slot at the backside of your laptop which is located in the central/middle of the computer if you turn the laptop up side down. you will have to unscrew and open the cover. and that is where the RAM slot is located. Regards Gizokieth
Oct 08, 2009 | HP Compaq Presario V5000 V5100 V5200 V5300...
Windows won't start after adding ram
Sometimes, when you add RAM, you need to tell the computer that you have, do that by going into the BIOS when you start up your computer. Or it could be a wrong ytpe of RAM! Hope one of these idias has helped you.
May 19, 2009 | Compaq Presario 900 /1500 Series EVO...
Is my presario v5000 using my ram upgrade
where did the ram come from? did you buy it or pull it from another computer? its possible the chip is either defective or not for your computer depending on where you got it, its also not that much of an increase so you may not notice it i would suggest getting another 1g stick because yours should take 2g 1 in each slot.
Jan 24, 2009 | HP Compaq Presario V5000Z Notebook
Need to add ram
its depend that upon your RAM slots. If RAM slot is two then its means you can add only 2 RAM.
Jan 02, 2009 | HP Compaq Presario V6000T Notebook
Compact presario v5000
remove your RAM from their slot then insert it again, hopefully this may solve your problem
Oct 16, 2008 | Compaq Presario 700 470024-192 Notebook
Blank screen problem witn presario v5000
This will not kill your computer don't worry.
What would be mt suggestion for you, please get your presario v5000 reimage with all the drivers.
Aug 25, 2008 | HP Compaq Presario V5000Z Notebook
Adding memory
You shouldn't,t have to go into bios at all. Shut the computer off, install the ram, turn on computer. The bios will see the memory automatically.
Aug 08, 2008 | Compaq Presario 5440 (152507-004) PC...
Compaq evo n610C adding ram
Hi, the ram is located under a cover to the left of the mouse pad, you need a flat blade screw driver to pop it open.
Jun 26, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
422 people viewed this question
David Payne
David Payne
