Question about LG W1934S-BN 19" Monitor
My monitor has gone blue, what do I do - LG W1934S-BN 19" Monitor
  • LG Master
  • 3,287 Answers
Assuming the monitor is powered (if unsure, check the that power cord is connected to a live 120 volt source and the other end is connected to the monitor), check the data (analog VGA or DVI) cable between the monitor and the computer. Make sure the connectors are firmly seated in the respective jacks, and held in place with the retaining screws where provided.
If all four connections (power in and out and the data in and out) are satisfactory, check your monitor's input "source" selection. This may be selectable via dedicated "Source" button on the monitor or from the monitor's "Menu".
When changing the source input types with the button, it will usually take a couple of seconds before an image will display, so allow enough time for the monitor to respond to the change. If changing via menu selection, it may not change until saved or exiting.
If the monitor refuses to display, it may be an issue with your video card. In this case you could try swapping the video card or the monitor to determine which is the culprit.
I hope you found this Very Helpful and good luck!
Posted on Nov 17, 2009
My monitor has gone a bright blue
Check the pins in the end of the monitor cable, look for bent ones. If it's okay re connect to the monitor and try again. Unplug the monitor and wait for a few seconds, plug power back in. Cycle power on the monitor. Then restart your computer. Wiggle the monitor cable on either end and see if the color changes.Good luck
Sep 30, 2012 | Microsoft 66I-00752 WINDOWS VISTA -...
Monitor lost color went blue contrast. now well not turn on.
The monitor has at least two issues, the color is lost and gone to blue screen, second it will not turn on. It will be cheaper to replace the monitor with a new one rather than fixing the Star Logic Monitor. But I would suggest using a spare monitor to check the computer for any possible issue.
Jan 08, 2011 | Star Logic 17" LCD Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Why my monitor screen has gone
well first check to make sure the cables are plugged in and not frayed or kinked. then check to see that the cord from your manitor to your tower (its normally blue) is screwed in because if it is not it will have a hardtime finding connectivity
Hope this helps!!
Jul 15, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Display will not come up, screen remains black, blue light on front of monitor flashes on and off
Check that the monitor is still receiving a signal it could have gone into standby mode.
If not you either have a faulty inverter or the back light has gone, to test this when your computer is on is to check you can still see a faint image on the screen that means the backlight has gone, if not its the inverter.
Jan 22, 2010 | Gateway FPD1975W 19" LCD Monitor
HI,the color on my monitor has gone blueish its like
try reseating or/replacing the cable. If the connection isn't good then you can lose one of the three basic color channels resulting is a tinted screen color
Jan 08, 2010 | Acer AL1916B 19" LCD Monitor
The screen was unplugged and now when plugged in the blue light around the power buton just flashes
I tried the reset procedure, i've left it unplugged now for a week and upon ... Now the fifth died. This time, no illumination, just flashing blue light. ... The screen is completely black, the power button is dark blue and no amount of ... The monitor was gone for about 2 weeks (maybe 3) I left it plugged in and ...
deliverator.silverfir.net/?p=369
Dec 04, 2009 | Samsung SyncMaster 932B LCD Monitor
Everything's Gone Green !!!
Try it in someone else's computer.
To see if it is the Monitor or the Video card...
Jul 07, 2009 | LG Flatron L1750S 17" LCD Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
LG W1934S-BN 19" Monitor Logo
318 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
