Question about Refrigerators
My Matsui under counter fridge smells of old milk/veg really badly despite cleaning out thoroughly including catch tray at back and downpipe. It is only 1 year old - any advice gratefully received
    Scholar:
  • 53 Answers
Can you pull out the fridge and check that the plastic power cable has not been pressed against the compressor at the rear/bottom of the fridge?
Usually, overheated plastic cable smells like rotten veg!
Posted on Nov 17, 2009
Cleaning the interior, especially the bottom where heated milk gets burned on.
90% of all my service calls were due to machines that were not cleaned DAILY. About a third of those were for espresso machines with a steamer and the rest for auto frothers. Most Barista's don't use auto frothers as they have very little control over the frothed milk. (Heat, froth density, firmness, holding, etc.) Milk(any type) will clog a machine in minutes if not cleaned up after use. Spoiled milk will contaminate any product with curds and have a bad smell to coffee.
* Clean up after any milk usage. Seconds count after frothing milk with a steam wand. Get workers in the habit of removing milk pitcher from wand and give the wand a short blast to flush the wand and wipe with a damp towel (tower wash and sanitized often) Leave the folded (quartered fold) next to wand on drain tray where it's always handy.) It only takes seconds to perform and customers appreciate the cleanliness and professional look.
* take a tip from Bartender's; you HAVE TO WASH WITH DETERGENT! when washing glasses that had milk drinks in them. Nobody want's a sour milk smell in any drink. Milk film can only be removed with soap and water and a brush. That's why you see automatic cup washers on every bar set up. It does take elbow grease to get these cups clean.
* Harden, cooked milk (coffee to) is best soaked in clean water (detergent optional) and let it sit over nite. This is a good practice to keep everything coffee/milk stain free as everything is washed/rinsed prior to use in the morning.
* Really, really baked on coffee (left burning on warmer for several days, weeks. Will need an urn cleaner to soak and wash out several times. Check with your coffee vendor as most will just swap them out with clean ones. Otherwise ask for urn cleaner from them and follow instructions. Hot water with a tablespoon of urn cleaner for each pot and let soak over nite. wash and rinse thoroughly prior to use.
"Washa-washa!" Aloha! ukeboy57
Jan 10, 2018 | Coffee Makers & Espresso Machines
Why does my refrigerator smell so bad?
PUT A BOX OF BAKING SODA IN REFRIGE AND 1 INTO FREEZER ALSO. BUT TAKE EVERYTHING OUT, MAKE SURE NOTHING SPILLED AND IS UNDER A DRAW ROTTING. IF ALL IS CLEAN INSIDE, PULL OUT REFRIDGE IN BOTTOM BACK IS AN EVAPORATOR PAN FOR CONDENSATION, SOMETIMES SOMETHING CRAWLS UP INSIDE GETS TRAPPED AND DIES.
YUCKY BUT VERY REAL
Jan 05, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
My evaporation tray is full and smells as milk has split into it and gone off -it is making the kitchen smell. Does the evaporation tray unattach from the back of the fridge?
if you can get to the tray pour in some clorine bleach,or pour some down the drain hole,this will kill any smells/bacteria.(works with all fridges).
Jan 11, 2011 | Zanussi Refrigerators
Smell from fridge back because of milk leakage
the bad milk smell got into the drain pan if you look next to the compressor there is a drain pan you need to clean it. and also the pip that go from your freezer to the pan.
not so hard to do but will make sure the small gone.
I hope you find this Very Helpful and best regards!
Jan 04, 2010 | Refrigerators
Terrible odor from bottom front of fridge
The milk probably is gone, but there may be something in your coils. Inspect from front at the bottom, behind toe kick trim or from the back by removeing the access panel on the lower back of the frig. Coil cleaning should be done with the frig unplugged, vacuum out the dust and with a small brush resembling a bottle brush but smaller. clean between the coils. Don't force the brush. Twisting with light pressure will work just fine.
Jul 09, 2009 | Refrigerators
Smell under the unit, kenmore elite model number 44703
Hi: Not knowing your model number I would look where the milk was spilled and see if there is a hole. Possibly behind a panel for the defrost water. If so pour a little clorox bleach ane water in it. If not look for any cracks in the liner of your fridge. Those will expose the foam insulation to absorb the milk and cause odors. Clean them and seal them with teflon tape or a repair kit from the manufacture. On the off chanch the mild spilled to the front of the fridge and leaked behing the front grill the coils there are quite warm and will spoil milk fast. Pull the grill off and clean. I hope this helps, Jeff
Jul 07, 2009 | Refrigerators
Spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
May 06, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
I have a homeking fridge freezer and there is a really bad smell coming from the fridge which is not because of food. i have emptied the fridge and thoroughly cleaned the fridge but the smell is still...
Hi, i have the same problem with my Homeking fridge. Because it is a frost free firdge, there is a little resevoir at the back, with a small little tube leading from the base of the fridge into it. There are 2 screws holding it in place. Unscrew these but keep the resevoir firmly in place as the nasty parmesan-type smell is actually stagnant water and you really really dont want to spill it. Empty it and then what i did was bleach and anitbacterialise the resevoir tray and the little tube thing. Though I had the problem solved but now it is doing it again less than 2 months after this, so I'm going to contact the people who sold it to me. This is how you get rid of the smell though!!
Good luck
Laura
Aug 14, 2008 | Refrigerators
Refrigerators Logo
256 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
