Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Problem Printing accurately colors from Corle Draw to Bizhub C252
Printing from coral draw to Minolta Bizhub C252 greys look reddish. Printing from C3120 looks grey with fiery. Treid C253 with fiery and corel seems to block spot on feature. Is printing from C252 postscript driver with C3102 profile loaded a solution? Is printing to C252 with C253 postscript driver with C253 ICC profile loaded on corel a solution?
  • 167 Answers
Re: Problem Printing accurately colors from Corle Draw to...
The reddish greys are something a Fiery will correct, that is part of it's function. (GCR).
I would try turining colour management off, or rasterizing the file in Corel. I believe there is an option in the print window.
Have you tried making a PDF of the file and printing that?
Using the ICC profile could be a solution, but the Fiery is what is needed.
Posted on Feb 25, 2008
0 characters
3 Points
I have a problem printing accurate colours, all photo's and images print dark. If I print the same artwork on Xerox 7545 the colours are bright and accurate.
What about contacting Minolta - multiple options at this link: (Minolta Support and Downloads) index If no satisfactory answer consider returning printer.
May 21, 2016 | Konica Minolta Bizhub C364 Color Copier /...
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Dec 14, 2015 | Konica Minolta BizHub C252
C2477 ON C252
no such in the service manual
Jan 20, 2014 | Konica Minolta bizhub C250 All-In-One...
Black lines running down on the Konica Minolta bizhub c252 copier?
Does this happen when you print? does this happen when you make copies on the big glass. Does this happen when using the document feeder?
Jan 23, 2012 | Minolta Printers & Copiers
Printing to bizhub c252 from one computer a problem
s it a shared printer? if it is, install the driver as a local printer
May 27, 2010 | Konica Minolta bizhub C250 All-In-One...
Printing PDF to Bizhub c252 issue
I had this once. We simply deleted the Printer Driver and reinstalled it. Also, when reinstalling the Printer Driver we chose the PS (PostScript version).
Try that - hope it helps
Kind regards
Apr 26, 2010 | Konica Minolta bizhub C250 All-In-One...
Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Nolasco from argentina - DPI Grafica
Jan 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Bizhub C250/252 ICC Color Profile
HI i am fron DPI Grafica SH and have made test of diferents ICC profiles.
I will tell you how is my system to get to correct colors an sharp texts.
First - i print fron Adobe Ilustrator or Adobe PDF Profesional. If you have your file in Corel Draw export it to pdf or Publish a PDF File.
Second - I select s"sRGB IEC6 1966-2.1" this profile prints acurate fonts and colors that match whit de monitor. Is a little bit desaturate if you compare with " COATED Foagra". This one prints blurry fonts and blur edges.
This is the best result that i can get after print tests with all de ICC profiles.
Greetings and i hope that you can solve this problem.
Oct 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
736 people viewed this question
Top Konica Minolta Printers & Copiers Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Printer and Copier Expert? Answer questions, earn points and help others
