Question about Cameras
Which is better canon 459d vs. sony a500? - Cameras
Tip
VOB movies for Acer Iconia Tab A500-Stream DVD VOB to H.264 MP4 to Acer Iconia...
Transfer/Play DVD VOB files to H.264 MP4 for Acer A500 <br />Join multiple DVD vob files into one for Playback on Acer Iconia Tab A500 <br /><br /><b>A VOB file (Video Object)</b> is a container format in DVD-Video media. VOB can contain video, audio, subtitle and menu contents multiplexed together into a stream form. VOB file can contain H.262/MPEG-2 Part 2 or MPEG-1 Part 2 video, MPEG-1 Audio Layer II or MPEG-2 Audio Layer II audio, but usage of these compression formats in a VOB file has some restrictions in comparison to the MPEG program stream. <br /><br />How to convert and play DVD VOB files on Acer Iconia Tab A500? For Acer Iconia Tab A500 can not accept this format. <br />Acer Iconia Tab A500 is also a great media player which supports a lot of media formats including files with XviD, MP4, H.264, H.263 as video format and MP3, WAV, WMA, eAAC+ as audio format. So you need to convert the files before transferring and playing them on Acer Iconia Tab A500. <br /><br />Aunsoft Video Converter is the best <b><a href="http://www.aunsoft.com/video-converter/">VOB to Acer A500 Tab converter</a></b> for you to transfer files to tablet. It makes it easy to transfer VRO files to Android tablet by converting DVD VOB to MP4 for Acer Iconia Tab A500. You may also deinterlace VOB to progressive mode for perfect playback on Acer Iconia Tab A500. <br /><br />Below is the quick step-by-step guide for you to <b><a href="http://canon-videoconverter.com/2011/06/join-multiple-dvd-vob-files-into-one-for-playback-on-acer-iconia-tab-a500/">transfer and play VOB to Acer Iconia Tab A500</a></b> via Windows XP, Windows Vista, Windows 7. <br /><br />Step 1. Load VOB to Aunsoft Video Converter. <br />Run Aunsoft Video Converter as the best VOB to Acer Iconia Tab A500 converter, and click the "Add" button to import the .vob videos. <br /><img src="a500-vob-converter.jpg" /> <br /><br />Step 2: Choose the suitable Acer Iconia Tab A500 format. <br />As we know, Acer Iconia Tab A500 supported video like XviD, MP4, H.264, H.263 format like MP4. Here just take H.264 HD Video (*mp4) for example. Choose Common Video &gt; H.264 Video (*.mp4) as output format. <br /><br />Tips: Click "Settings" to set the Video/Audio Parameters like Size (resolution), bitrate, frame rate, etc to be more suitable for Acer Iconia Tab A500. For example: Set Size/Resolution to 1280*800 pixels. <br /><img src="set-a500-profile.jpg" /> <br /><br />Step 3: <b><a href="http://www.aunsoft.com/video-converter/">Convert/Rip DVD VOB to MP4 for A500</a></b>. <br />After all the above settings, you can click "Convert" to start <b>conversion VOB to MP4 for Acer A500</b>. Only a few munutes later, you can get the generated files by clicking "Open" icon. <br /><br />When the conversion is done, just connect Acer Iconia Tab A500 to Widnows PC via USB cable, and mount the converted videos to Acer Iconia Tab A500. <br /><br /><b>Tips:</b> If you want to <b>join multiple DVD vob files into a large files for smoothy playback on Acer Iconia Tab A500</b>, just check "Merge into one file" to make it.
on Jun 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
C21:00 on sony GV-A500 what to do?
It has the error code for condensation cheack the sensor (see photo link below) If it is very dirty it will appear like a small square circuit board about 5mm x 5mm with a black blob in the center and two solder connections at the top. After cleaning you should see a bright copper circuit where the black was prior to cleaning. Gentle wiping with an alcohol moistened cotton bud is all it needs. it looks like this http://www.dvinfo.net/forum/attachments/sony-hvr-a1-hdr-hc-series/12072d1241502823-moisture-condensation-dsc01114.jpg
Apr 27, 2011 | Sony GV-A500 VCR
Dont know how to turn on flash polaroid a500 camera
Hi onestoppa972, I could try and explain it to you, but I think it would be better for you if you were to read it and have the pictures for reference. If you don't have the manual, you can download it here: http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/A500-_E Just follow the instructions and download it for free and it shows the various flash settings. If I can help you further, please let me know. Thanks.
Jeff
Nov 23, 2010 | Polaroid A500 Digital Camera
Hi, I currently own the SONY GV A500 and have no problems with it..I was just wondering if you knew how or where I could purchase the AC V615 AC Adapter cable being that I have misplaced mine. Thanks!
This item is out of date but you might get one from EBAY as the one I found here:
http://compare.ebay.com/like/150466893702?ltyp=AllFixedPriceItemTypes&rvr_id=124113446851&crlp=1_263602_263632&UA=WXF%3F&GUID=9d3242671250a0266b71adf1ffdf1a43&itemid=150466893702&ff4=263602_263632
$35.00
Mar 11, 2010 | Sony GV-A500 VCR
I get C32:20: flashing on screen and i cannot remove cassette Sony GV-A500
C:31:20 Take-up reel side tape slacking when unloading. Possible worn belt or dirty or broken drive roller track and or drive wheel sensors.
Jul 15, 2009 | Sony GV-A500 VCR
Broken screen
well it could be replaced but to be honest you would be better off buying a new one it would cost you more to fix it than to buy a new one just like it
May 02, 2009 | Polaroid A500 Digital Camera
Video walkman gv-a500
did u try any other cam?
Jun 10, 2008 | Sony GV-A500 VCR
Panasonic LUMIX DMC FZ50 Vs. Canon EOS 400D
When it comes to DSLR, Canon scores better than Panasonic. Have a look at dpreview.com for pic samples from both the cameras.
I own a 350D for the last 2+ years. I havent come across any maintenance costs. However, the urge to upgrade is always there :)
- Ranjit
ranjit@supportminds.com
Oct 24, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
93 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
