Question about Sony Ericsson K750i Cellular Phone
Faulty navigation key button can it be repaired if so how much approx please john
Running when put up but turn key and get nothing
Bernice, could be dead battery, faulty fuse,solenoid or starter.
Have a technician check/diagnose and give estimate of repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 07, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
AEG Lavamat washing machine model 76850, shows a blinking key and makes clicks and after that shows E40. Thanks John
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensing circuit faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Aug 02, 2014 | AEG Washing Machines
How do you replace your ignition switch?
special key tumbler and key that must go thru key decorder. after market shop will charge approx 300.00
Dec 23, 2012 | 2000 Oldsmobile Intrigue
How to delecte recent logs
These steps should be more or less similar.
  • Press the OK button for Menu
  • Select Recent Calls, using the navigation keys
  • Select All (4)
  • Select the Recent Call type, using the navigation keys, from the following:
  • Missed Calls
  • Received Calls
  • Dialed Calls
  • All Calls
  • Highlight desired Recent Call, using the navigation keys
  • Press the right soft for Options
  • Select either Erase (2) or Erase All (4), using the navigation keys
  • Highlight Yes, using the navigation keys
  • Press the OK button to confirm call log deletion
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 22, 2011 | Samsung SGH-T309 Cellular Phone
I would like to unlock my DVD player to play all regions PHILLIPS DVP3110K
# Turn On unit
# Press the Setup button on the remote
# Navigate to the Preferences page using the Right arrow key
# Press the Down arrow once to enter the Preference page
# Enter 1, 3, 8, 9, 3 and 1 on the remote
# You will now see the current region code displayed
# Use the Up/Down arrow keys to select the region required or 0 for all regions
# Press the Play or OK button on the remote
hope this helps
john
Jan 18, 2011 | Televison & Video
I have two thick black lines running vertically on the plasma
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Sep 08, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
I have mazda 2 with key fob problem it locks car but will not unlock???i have to use key please help!!!!
I had a similar problem with a second-hand Mazda2, was intermittent too so the seller kept telling me it was OK. Eventually turned out to be a loose connection with the fob, I bought another off eBay and billed the garage for it, found instructions for programming it online and it's worked ever since.
May 15, 2009 | 2000 Mazda 626
I cannot remove the key from the ignition
Jiggle the steering wheel abit as you try to remove the key
Robert
Please rate this solution
Jan 30, 2009 | 2007 Chevrolet Cobalt Coupe
Problems with Gearshift 2004 Lincoln Navigator
Turn the key forward a notch then it should come out. If you are turning the key all the way off it enables the accessories (radio etc), locks the key in the ignition and disables the gear shifter.
If thats not the case then there is a button to be depressed so that the key can turn anticlockwise>off another click and the key can be removed.
It'll be one or the other....faulty ignition lock is the only other diagnosis
Jan 08, 2009 | 2004 Lincoln Navigator
Keypad buttons ( navigation keys only) not working
Both navigation keys and number keys stopped working
any ideas
Aug 18, 2008 | Nokia 6500 Slide Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
47 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
