Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Where does the hdmi go on my tv - Sharp Aquos LC-42D62U 42 in. LCD HDTV
  • 117 Answers
Make sure its not white as this is dvi/but anyway its a little port like a usb / it only takes hd devices
Posted on Nov 17, 2009
How to hook a hdmi to a Phillips flat sceen tv that's not a smart tv
Does the TV have an HDMI port on the back of the TV? Example: DVD player HDMI out to TV HDMI in. then on the TV select input and choose the HDMI port number you connected the cable to on the TV
May 11, 2017 | Televison & Video
Cannot get the hdmi to work
My Tv won't recognize my computer when connected via HDMI [Solved ...
www.tomsguide.com/.../57797-4-recognize-computer-connected-hdmi
4 days ago - 43 posts - ‎36 authors
I too was able to get the HDMI output to work and then later on stop working. ... I'm also experiencing this issue, but still can't make the TV ... Audio over TV problem using HDMI cable
Jun 30, 2015
When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
My TV doesn't accept PC HDMI [Solved]
Dec 7, 2012
More results from www.tomsguide.com
TV won't recognize laptop when connected via HDMI ...
Dec 26, 2015 | Televison & Video
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
When i go to hook up a hdmi cable to my philips flat screen it wont recognize that i have a hdmi plugged into it. so what could that be the tv? the hdmi works with my other tv though
This model has 4 HDMI inputs, do you get same problem in each HDMI input?
Did you checked HDMI input with any other video source like dvd player or PS3 etc instead of cable box?
Below are few helpful tips to connect HDMI input..
1. Ensure that your HDMI cable is certified.
2. Press SOURCE on the remote control to switch to another source and then switch back to the HDMI source.
3. Reset the accessory device and the TV.
• Turn on the TV
• Select the HDMI channel
• Turn on the accessory device
4. While the TV and the accessory device are powered on, unplug either end of the HDMI cable and then reinsert the cable.
Try above options and if tv still does not show picture of any video source through HDMI then it seems problem of HDMI processor located on main board, visual check is needed by qualified tech or call Philips if tv is under warranty.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Philips 42PFL7403D/27 42 in. LCD TV
Reset HDMI on non HDMI tv
Put The HDMI Into your old tv then switch it to AV MULTI then put the av in then it will ask if you want to keep these setings then select yes and then put the AV MULTI into your new TV.
Mar 21, 2009 | Sony Playstation 3 (PS3) Console
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Hdmi or optical
There are no noticable differences between HDMI and optical except price. Although optical is less prone to EFM interference, HDMI can carry a wider bandwidth, depending on quality, but cost a lot especially long runs (10 ft or more). Also optical cables are not prone to connector tarnish which occurs even with gold pins of HDMI
May 07, 2008 | Onkyo TX-SR605 Receiver
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
62 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
