Question about Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery
My electrolux is not keepin the temp cool enough
    Scholar:
  • 53 Answers
Has this ALWAYS been a problem, or just recently?
You need to give more details about the fault.
Is the fridge/freezer located near to a radiaitor, for example?
For info, the inside temp of your fridge should be around 4C and the freezer should be around -21C.
Posted on Nov 17, 2009
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Electrolux refrigerator not working properly i have change new one picture i ve attach here thou sometime it run but after few minute it stop please suggest what should i check.
Hi, have you tried adjusting the thermostat control, if the fridge is not cooling enough you can set it to a lower temperature. There will be a rotating knob somewhere on your fridge that can turn the temperature down. Sorry if I appear a little confused, the fridge is supposed to stop after a few minutes of cooling, it should not be using the compressor all the time.
Maybe lowering the temp will soet the issue.
Jun 15, 2015 | Electrolux Refrigerators
My electrolux dff 44 high temprature light is on regularly on and the cooling is slowly slowly low
If the cooling is getting worse, perhaps you have a leakage of the cooling fluid?
If the motor is running all time, and still not cooling enough I would look there.
An perhaps you start saving for a new fridge.
Jun 15, 2014 | Electrolux Refrigerators
Cooling temp sensor electrolux
The fz sensor should have 32000 ohms at 32 degrees if it is ok replace the main control. The sensor has a connector to plug into.
Feb 09, 2013 | Electrolux Refrigerators
Eob5630w oven shutting down before set temp isreaced aprox 198c also cooling fan not comingon
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
Jan 05, 2011 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EW26SS65GS0 Refrigerator. Temps going up. Red High temp alert and blue adjusting temp indicator lit. Suggestions?
Same problem for past month, tried replacing motherboard and today still showing Red High and adjusting....$500 so far and three service calls...what to do...food thrown out and good thing my garage is cool to store some stuff.....
Dec 18, 2010 | Electrolux Refrigerators
Fridge side won't regulate temp. however the freezer will freeze to -9 and stay right there! How do you test the thermostat? or is this a common problem. The fridge was built in 01' and nothing has been...
the thermostat is either off or on, and it controls the fridge temperature the freezer is just a by product of the remaining gas from the fridge usually -20/30 degrees lower than the fridge, two problems would cause this leaked gas would reduce the cooling capacity of the freezer but the fridge should stay ok although the compressor would be constantly on trying to keep temperature. the thermostat can fail after time not being able to keep a regular temp and not switching the compressor on enough to cool the system. unless you have a frost free where is usually a relay that controls the compressor witch have a life time rating of so many operations.
Jul 23, 2009 | Electrolux Refrigerators
I've got an electrolux frost free fridge freezer and it is not freezing. The fridge is cool and cold air is entering the freezer compartment but it is not cold enough to freeze the food. I've removed all...
remove the back panel inside the freezer and check for ice build up on the evaporator pipework. if ice build up, this prevents air flow and hence temp rises.
remove ice carefully with a hair dryer and it should work. if problem comes back, you have a problem with the defrost system and get back to me if you want
Aug 05, 2008 | Electrolux Refrigerators
Open Questions:
I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defros I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defrost. The top part of the freezer was heavily encased in ice (evaporate coils I think). After perusing the web for advice I removed the the front vent, the back wall and dropped the coil panel to access the fan. The fan had obviously not been working for some time cos it was covered in ice. I defrosted the whole fridge for 2 days. Turned it back on and the freezer part seems fine although v cold. The fridge seems not to be cooling again. The compressor seems to be constantly running. Current temps are fridge 12, freezer -25, ambient 16. I haven't got anything in the freezer yet. Thermostat set on 1 (1-6 setting). How is the fridge cooled? When I removed the evap panel I could not see how cold air gets to the fridge. There aren't any holes in the fridge so I am assuming the back panel should be cooled. If the thermostat is u/s would the compressor still run? Does the thermostat control any duct vv from freezer to fridge back panel? I attempted to remove some of the insulation from the fridge rear but was worried about cutting anything under it so abandoned that. Wife now giving me grief. Pse help. Andy
Mar 02, 2017 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
See all Electrolux Icon 22.6 cu. ft. Counter-Depth Questions
Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery Logo
239 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
