Question about Xerox Phaser 6200B Laser Printer
Wifey touched usb cable into ethernet port and display went black. Turned off (and removed) power, screen lights momentarily on fire up then goes black. Any ideas?
  • 53 Answers
Sorry to say but looks like your ESS board is gone for a ball of chalk. needs to be replaced
Posted on Nov 20, 2009
M93p suddenly the screen goes black screen
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck
Jun 19, 2014 | Lenovo M93P Tiny I7-4765T 8GB 500 WIN7/8
Does this have a 3.0 usb port?
Memory Module Specifications Total Memory Size 6GB Memory Type DDR3 Monitor Specifications Display Type Active Matrix TFT Color LCD Screen Size Connection Type HDMI Maximum Resolution Touch Screen No Media Ports LAN Ports 1 - RJ-45 Ethernet Connector USB Ports (Total) 4
USB Ports Powered (Included In Total) 2x USB 2.0, 2x USB 3.0
Audio Out Jacks Processor Specifications Processor Brand AMD Processor Class A6 Processor Number 5200
Processor Speed 2 GHz Hard Disk Drive Specifications Hard Drives Included Capacity Interface ATA Hard Drive Types Hard Disk Drive
Apr 26, 2014 | Acer Aspire Z Series All-in-one Touch PC...
Screen on Gateway FPD2185 stays black.
The back light is out. Might be the inverter or the tube.
Feb 15, 2014 | Computers & Internet
Playstation is on but screen is black
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 30, 2010 | Sony PlayStation 3 40GB System
Laptop display went black after inserting a USB cable for iPod.
count the beeps on startup, and makes sure that you count if any are long beeps and short beeps as these are bootup error codes.
Mar 24, 2010 | Compaq (169174-002) - (Refurbished)...
IPod's USB cable causes black screen...HELP
First of all thanks for posting so much info, it helps us give more concise answers!
I'd be tempted to be thinking along the lines of a software issue as well. 2 quick things to try 1st; what happens when you plug it in to a different USB port? Have you downloaded the latest version of iTunes?
Dec 13, 2009 | Computers & Internet
Blackout in my house, Xbox 360 ethernet port broken!
All the message means is it can't find the internet, so your internet must have went down.. your systems should still be working fine. I don't know much about using usb for ethernet, but that sounds like it would work no problem.
Apr 04, 2009 | Microsoft Xbox 360 Console
Yellow flashing light on dimension 5051
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 20, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer moniter goes black but CPU is but not functioning
1. power-off your computer. unplug video and power cables. remove your video card hardware from its slot and plug it back in. put the video and power cables back. power on your computer. try this up to 3 times until your system is back to normal. it will be best if it works your first try. if it doesn't consider changing you video card.
Jun 28, 2008 | Evga (131-K8-NF44-AX) Motherboard
Audiovox SMT 5600 will not charge
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Nov 18, 2006 | Audiovox SMT5600
Xerox Phaser 6200B Laser Printer Logo
187 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
