Question about Cell Phones
After charging my phone with charger supplied with sagemmy411c mobile display reads hardware failure battery error. whats going on ? thanks
Samsung mobile
If it is not able to be charged you can still buy a couple of spare batteries with wall charger cheap from ebay or the like. Take the battery off the phone and use the battery charges directly in the wall charger.
Apr 11, 2014 | Samsung Galaxy S III S3 GT-i9300 16GB...
Charging error which leads to dead batteries.
you should use a charger which is compatible with your mobile infact the original charger for your mobile or you should get your mobile's charging port checked from an expert.
Thanks.
Apr 30, 2011 | Sony Ericsson Z750 Cellular Phone
My Motorola SLVR L7 Cellular phone displays invalid battery even as i have changed the battery. It does not charge also, please help me.
hi
there must be error functioning in hardware of your mobile.. contact your service men of your mobile. this will fix your problem..
thank you
Dec 22, 2010 | Motorola Mobility SLVR L7 Cellular Phone
THINKING IT WAS THE BATTERY I BOUGHT NEW BATTERY . WILL NOT CHARGE SO I PUT BACK OLD BATTERY AND STILL WILL NOT CHARGE. USUALLY IT WILL BEEP WHEN I PUT BACK IN CRADLE. BASE LIGHTS ARE ON /CHARGE INDICATOR...
Hello
This is either a problem with your charger or the charging port of your phone
Try charging your phone with another charger that works with you phone to see if it works,if it doesnt then you need to change your phone battery charger
Also you should wedge your battery at the bottom with a folded piece of paper because the battery might have become loose and doesnt fit in properly into its compartment so by doing that you will be providing better contact between battery and battery terminal.
If the above still doesn't make the battery charge then the problem is from the charging port of your phone.
The charging port is where you connect your charger into,it is probably damaged and needs to be looked into and replaced.
Oct 05, 2010 | Cell Phones
How to solve charging problem
Dear, Could you explain the problem like is there a charging error display on your screen or is this problem of your charging jack.
well i can help you, if there is charging errror display on your mobile screen so your charger or your battery must be corrupt or non-geniune.
OR if there is problem with your charging jack so it is very easy to fix this problem, you just need to buy a new jack it is very cheap. Then if you can change it yourself so it is better otherwise you just go to a cerified mobile phone repairer and let him chande your jack. Changing the jack is just like 1 2 3, you just pull the jack back after opening your phone and push the new jack.
Thanks
May 06, 2010 | Sony Ericsson P990i Cellular Phone
Charging
charger not supported can be a software problemor a hardware problem.in an case we need to take it to nokia centre.before that check with another charger weather it is giving the same error or not.this is one of the phones which supports usb carging as well so whenever ou connect a charger you dont see anything on display.but if the phone is completely dead it takes atleast 15 to 20 minutes before it starts charging.
Can be battery problem..
Thanks
Fame !
Apr 27, 2009 | Nokia 3110 Cellular Phone
My LG phone isnt charging, what problems could there be?
please check this firstand try to put on other mobile unit that is compatible.
1. charger
2. battery
if it still not working probably the problem is in hardware of your device and that is what we call "not charging"
the last option that we can do is to get you unit to a mobile technician and ask then to check the charging device of the unit.
thanks
Feb 19, 2009 | LG OEM VX8500 Series Vehicle Charger ,...
China Make N95
dear,
charge the phone with its own charger. dont use universal charger or other nokia mobile charger. china mobile have this problem. so charge the battery with the charger that came with it. hope ur problem will be solved.
regards,
Jul 23, 2008 | Nokia N95 Cellular Phone
Battery problem for my k800i
if charge down in 3 hours mean battery problem. if the mobile show "not charging" message mean charger problem.
Jul 07, 2008 | Sony Ericsson K800i Cellular Phone
Cannot charge the phone
West Loop - try a new battery if that does not work, try a new charger then take the phone and have the usb charging port replaced.
you need to take the phone to a mobile service center and have them replaced the usb charger.
Mar 27, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
