Question about Panasonic (KX-TDA200)
I had a faulty card on the tda 200. i replace with new ones. but dlc 16 too was faulty. now i cant make the consul phone work. so will like to get help how to go about it
  • Panasonic Master
  • 2,460 Answers
Call a dealer. The replacement DLC-16 card requires registration in the U.S. and probably elsewhere. It also needs to have updates performed to get it to the current software.
As far as the defective card, if it was made prior to 6-07 (s/n 7Fxxxxxx), it was subject to recall. Pana warranty is 2 years, but it MAY be fixed for free.
Of course, if you don't live in the U.S. none of this may apply :-)
Carl
Posted on Nov 17, 2009
Some analog line in not working on kx tda 200
have you tested the same line directly with an analog phone?Is it working?
Oct 09, 2012 | Panasonic Kx-tda0196 Remote Card For...
Cant get movie to come on.it says to hit play button.cant find any such button.picture comes on but that is it
The Polaroid TDA-03211C has the Play/Pause and Stop/Eject buttons on the TV on the side of the TV near the DVD slot. They are separate from the other control buttons. (They are closer to the back of the TV relative to the DVD slot with the stop button the lower of the two. The play button is just below the media card slot behind the DVD slot.) The original remote also a Play button (center two rows above the channel and volume toggle buttons).
The manual for the TDA-03211C is available as a PDF from HDTV solutions: http://www.hdtvsolutions.com/pdf/tda03211c_ug_en.pdf . See page 12 (page 14 of the pdf) for the controls on the TV and page 14 (page 16 of the pdf) for pictures of the remote.
I hope this helps.
Sep 04, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Hi i have a nokia 16 16 cell phone i want to use the sim card that i have been using for about five years but when i insert it in to the 16 16 the monitor diplays SIM NOT VALID what can i do? the IMEI no ...
Dear,
Your phone is locked to a specific Network so that you can not use any other SIM apart from that network.
You need to unlock your phone, so that it can accept SIM from all network.
Phone repairing shops will unlock it for you for $5-$10 Aprox.
You can also search internet for unlock codes.
Hope that will help you to unlock your phone
May 10, 2011 | Nokia 1616 Cell Phone
Wont hook to a second wireless phone
Was it supposed to? A 7630 XDP only works if there is hardware behind it. That means the first 4 ports only of a TDA-15/30/50 or a combo card the 8-port card in a TDA-100 or greater. The DXDP only feeds a comparable 76xx digital phone.
Carl
Dec 24, 2010 | Panasonic KX-T7630 Corded Phone
I want to extend the extension numbers beyond134. is it possible with Panasonic KX-TDA 200
Not exactly sure what you're asking, so I'll give you 2 answers. If you mean extension number 134, the answer is yes. The whole universe of numbers are available to you and by default you can use 100-599 in a 3-digit numbering plan. You can grow beyond extension 134 if you have the hardware to support it.
If you're talking about 134 physical extensions, the answer is "maybe" The 200 has 11 card slots. Slot 11 is usually reserved for an option board for a message card and other features. Card slot 1 is usually a digital card for digital extensions, and you need at least one trunk card (slot 10?). That leaves slots 2-9 (8 total) for other cards. Each card is 16 analog or 32 digital extensions, so if the system is being used for single line stations, the answer is 128, but if digital you can expand the memory and address more than 128 extensions. Actually, I think you can address 256 ports before you have to expand the memory.
Carl
Oct 30, 2010 | Panasonic Lands Phones
I have a phone system in my house using the KX-T7633 model corded phones. I want to plug in a cordless phone in the back of the KX-T7633 so that I can be cordless, but when I do I can not get a dial tone...
In a TDA-30/50 there are FOUR super hybrid ports, the first 4 on the cabinet. In a TDA 100/200/600, there are NONE. Which one do you have and is your extension 101-104? If not, it won't work. You can probably wire an analog port to the first pair and use the same cable, but it will never merge with the digital set.
Carl
Aug 24, 2010 | Panasonic KX-T7633 Corded Phone
No dial tone kx174
That's a trick. Pull out the card on the bottom of the cabinet and see if you get dial tone from the cards in the middle and top positions.
I think A1 and A2 mean extension cards of which you can derive 32 extensions, and the 16 analog ports on the base cabinet. I could tell you about the TDA-100 or 200, so I hope you didn't pay a lot of money for the 174's.
Carl
Nov 07, 2009 | Panasonic Lands Phones
CHANGING THE TIME ON PHONE
I can give you the fast answer and the slow answer. Fast one is to go to the main phone, press PROG and dial **1234. The system should go into programming and you will be looking at system program 000. ENTER. From there, using a combination of the SEL, FWD and CONF keys, you should be able to navigate around the time change, using ENTER or STORE to save it.
The arder way is to grab the manual here http://www.public.carl.airpost.net/TDA/TDA_PTPM_32.pdf and start reading it from page 12 then follow the instructions on page 16.
Keep in mind that TDA programming is usually done from the master phone, or any phone assigned programming status. It may be all or NONE.
Carl
Apr 15, 2009 | Panasonic KX-T7636W Corded Phone
Problem in PBX kX-TDA 100
dear sir can i get softwear version 5 for tda 100 pbx exchange panasonic
Apr 11, 2008 | Panasonic (KX-TDA0104) (KXTDA0104) Power...
Panasonic (KX-TDA200) Logo
139 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
