Question about Roper RAS8445KQ Top Load Washer
  • 196 Answers
Could be a restriction in the drain line. You would be surprised at what can get into the drain lines.
With the machine empty, tilt it back enough so that you can get access to the bottom. Brace the machine so it won't fall. If there is a bottom soft panel please remove it. The water pump is located on the bottom of the motor. (It will be either white or grey.) Remove the hoses from the pump. (You are going to get a little wet.) check to see if there is any restrictions in the hoses. (I do this by blowing through them but you may want to do this in another way.) To check the pump, follow the motor toward the transmission. There is a coupler that connects the motor to the transmission. Turn this coupler by hand a listen to the pump. If there is any objects in the pump then replace the pump.
Also, while your under the machine it would be a good idea to check the motor coupler. Move it back and forth and check for any play in the coupler. If there is too much play then the coupler needs replaced. (A coupler that it severely worn can cause the same problem and still let the machine work.
Posted on Jan 12, 2008
Dish washer wont empty out leaves about 2 or 3 in in it
Drain hose clogged or Not ran in the proper draining position, under the sink where the hose ties into the drain system or garbage disposal, the hose should be higher than the connection point, I have fixed this by tie strapping hose to the bottom of the counter or sink, hope that helps ?
Feb 27, 2015 | Kenmore Dishwashers
Wont spin leaves water inside
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you !!
Jul 20, 2010 | Frigidaire Affinity ATF6000F Front Load...
My washer stopped during the spin cycle. Now I can get it to fill with water But aggitate and spin it just makes a noise and the tumbler is locked up tight
Your shaft coupler / motor coupler has likely broke. Not too hard to fix yourself, but you will have to remove the water from the washer first.
Remove the clothes, place them in the bathtub. Roll a garden hose from the washer to outside where drain water won't matter. Tape the garden hose to the drain hose, and lower the drain hose to the floor. Water will flow through the garden hose outside. Turn the washer over, follow directions supplied with new part, and replace the motor coupling. When finished, reorient the washer, remove the garden hose, place drain hose in the drain stand pipe. Run the washer through a couple of full cycles, then rewash the clothing.
Jun 11, 2010 | GE WBSR3140DW Top Load Washer
Unit will not spin
More information would be helpful..the limited information you've given leaves diognosis wide open to being any number of 100 things..does it drain water? Pump may be blocked.Some people just say my machine wont spin! .but really it wont drain & therefore it can't spin until it has drained first.
May 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
My wf t1001tp wont drain...can anyone help?
sounds like a blocked drain hose or a faulty pump motor..If the machine can be drained by putting the drain hose lower than the water level then the hose is not blocked and it may be the pump...Make sure the hose leaves the machine from under the tub and not high on rear of washer. Obviously water won't flow uphill..If the pump has failed a new pump motor is much cheaper than buying a whole new pump....Nomess
Apr 04, 2010 | LG WFT1071TP Top Load Washer
Dishwasher wont' drain ...leaves dirty brown water ing bottom of washer
remove drain hose under sink shop vac hase pump and sewer drain clean out inside washer food chopper in bottom rear of washer
Feb 04, 2010 | Hotpoint Dishwashers
Maytag Neptune Washer Wont Spin Water Off
The obvious place to check would be the drain pump and the drain pump motor.
Disassemble the drain pump and check for a blockage.
Make a jumper wire and connect to the drain pump motor to make sure it works.
Then report back.
Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 70 washer will not spin in some washing modes
Has this Washer got a drain water filter ? if so check it first. also some washers have a 'delicates' program which leaves water in the drum to stop creasing, check you manual.
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
