Question about Saeco Vienna De Luxe Espresso Machine
THE WATER DOESN'T COME DOWN AND AT THE END THERE IS AN EXPLOTION AND THE COFFEE GRINDS GETS DUMP IN THE APROPIATE PLACE
  • Saeco Master
  • 19,396 Answers
Hi.
If the water does not come through, then there is an "explosion", that means that there is a blockage somewhere inside the machine.
The water will not arrive to the filter , but it will gain excessive pressure, until getting vapourized and causing the "explosion".
A technician must take apart the machine to find the blockage inside the brew unit, chacking all lines.
Also ensure that the filter is not clogged.
If you need a quote on repair, or if you want to find out if Saeco will cover the expenses, call them at the number listed on the owners manual.
Regards.
Posted on Nov 17, 2009
Machine grinds beans but dumps coffee in box cup
hi , sounds like the dump valve solenoid has failed or the valve on the base of the brewer has failed probably stuck,.which is the more likely culprit. let me know if you require more in depth help.
its not a problem that can be resolved by a novice.
Mar 30, 2014 | Franke Saphira Espresso & Coffee Maker
Water tank is full, water gets hot but no water comes up through coffee grinds, using as pour over, not connected to water line.
Remove the sprayhead and check that for blockage. Pour water into the reservoir with the sprayhead removed to see if it flows. If water flows then the problem is the sprayhead. If no water then it is the brew tube and you need a deliming spring to clear out debris. If the only time water does not get through grinds thne it is possible the grinds are too fine.
Nov 16, 2011 | Brewmatic LA3 Coffee Maker
My expresso machine is grinding the cofee , it makes his cycle and at the end nothing came out. The grinded cofee is returned to the dreg drawer. Some time the machine is working and some time not.... i...
Hi
there are 2 knobs in the bean hopper. Turn the small knob down to the middle and try again. you can get too much coffee in the brew unit and it will dump the grounds instead of making coffee. If the grinds are to big or coarse, it will also dump the ground.
Oct 30, 2010 | Saeco Incanto Classic Espresso Machine
I have a Gaggia Synchrony problem: Whenever I press the brew button, the coffee grinder grinds the coffee and then dumps it before going through the water stage.
There is a lever above the center of the door on the side of the machine. Pull the lever 1 click towards the front of the machine and try again. You diodn't say what your grinds looked like, but if they a chunky your grinder is bad and needs to be fixed. That will cause it also to dump early.
Sep 20, 2010 | Gaggia Syncrony Espresso Machine
Diagnostics for saeco Easy
theres a micro switch that gets tripped when theres enough coffee which activateds the dump selinoid
Nov 18, 2009 | Saeco Easy Espresso Machine
Saeco Vienna. Wet cofffee grinds in the dump box.
It could be the grind on the coffee or the red group o-ring and the 2 o-rings on the white plastic valve need to be replaced.
Nov 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
26 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
