Question about Zanussi FJS1225W Front Load Washer
The drum seems to run crooked and rubs...
The drum seems to run crooked... It will turn for about 3/4 revolution - then it 'flops' against the rubber seal and rubs. Is it the bearings? How do I fix it?
Thanks
    Genius:
  • Zanussi Master
  • 1,466 Answers
You can buy new drum Spider which has bearing fitted check cost 1st...
Posted on Nov 17, 2009
As it spins very slowly back and forth it also makes the grinding squeeking noise.
Hi Robert.
What you describe sound like a distorted drum and/or collapsed bearings. The grinding noise is typical of bearings which are worn out, and the squeaking can come from the drum rubbing on the door seal.
Check if the inner drum is loose and flops up and down. Also spin the drum by hand and see if it's touching the rubber door seal anywhere. If it spins freely but make a growling noise your bearings need to be replaced..
Neither of these situations are good. A serviceman is probably required to know for sure.
Good luck.
Nomess
Check that drum (2nd below) is not rubbing on this door seal
Drum should rotate quietly and smoothly
Jan 13, 2015 | Washing Machines
LG WM 0642 HW Direct Drive Making a thumping sound when spinning and smells like burned rubber. Smoke coming out of durm when front load door was opened.
Hi Paul.
What you're describing is probably the inner drum rubbing on the door seal.
It could be because the rear bearing assembly has collapsed or because the drum is distorted.
Turn the drum slowly by hand and see if the gap between the rim of the drum and the rubber seal stays the same. This will tell you if the drum is 'round' or bent out of shape.
Alternatively, if the drum flops up and down inside the outer drum it would be because of bearing collapse
Either of these situations would require a service visit and parts.
Get a quote...
Good luck.
Nomess
Jan 11, 2015 | LG Washing Machines
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
When My LG Throm drum turns slow there is a sound of rubber rubbing against smooth steel surface.The outer door boot looks fine. Is there another gasket that could cause this? It does not leak anywhere at...
hello there.. there is a belt for the drum in the inner part of the machine.. if you smell something like burning then the belt needs to be replaced..
Apr 24, 2011 | LG WM0642H Front Load
I have a Whirlpoool 6th sense front loader. The drum is constantly rubbing against the front rubber seal which constantly whines and screams. Is there an easy fix???? We reported this to the service centre...
Few things to check as the gap tollarance between the drum and rubber seal is small. Open door and turn drum by hand. Look carefully and see if the drum has an uneven wobble which is touching the rubber. If it has, you need to send the machine back or frplace the drum. Sometimes the rubber is installed slightly off centre which alters the correct rotation gap. Seal would need to be removed and realligned correctly.(I would check the drum for any signs of not being truly round)
Aug 15, 2010 | Whirlpool AWM8143 Front Load Washer
Hello, I have a problem with my Eureka Powerline bagged upright vacuum. It has a 12 amp motor and is model #4352, Type D. It was probably bought new in 1998. My problem is, while vacuuming today the motor...
it sounds like a rubber sealing in the motor has come loose and is being constantly rubbed against the walls of the motor with would cause the smell and loss of motor speed caused by the fricton of rubber against the rod so if you can get to the motor try to open it and see if you can get it if not take it to a small engine repair service hope this was helpful:)
Nov 16, 2009 | Vacuums
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Whirlpool Dryer making a rubbing or jingle noise when running
there are wheels under the drum to support it take the front panel off and check those
Jun 24, 2009 | Whirlpool GEW9200L Electric Dryer
Asko T700 dryer
Seems like you need new drum rollers. If one(or both) is bad, the drum will rub in the plastic.
Dec 10, 2007 | Asko T700 Electric Commercial Dryer
Zanussi FJS1225W Front Load Washer Logo
421 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
