Question about Dryers
Replacing stats on hotpoint CTDOO condensor dryer, I have new ones , one has a green dot and the other a red dot. But not sure what position they go on the element unit. HELP PLEASE
    Genius:
  • 1,466 Answers
You will find that they only go on one way, the wiring lines it up to make it easy for you....
Posted on Nov 17, 2009
Hotpoint tdc32 has a thermadisc one shot (green dot) should this have continuity through it as i cannot find a diagram
Yes the thermostats should have continuity thriugh them, even if only one has failed, you should replace both stats together.
Feb 20, 2011 | Hotpoint Dryers
Our Hotpoint ctd00 keeps tripping the fusebox, we
Disconnect the heater thermostats by poulling a wire off each stat, and then try it, if it still trips, then could be faulty motor.
The stats are located at the rear of the dryer, behind removeable cover.
Mar 25, 2010 | Hotpoint Dryers
Hotpoint dryer not heating ctdoo
theremostate fault on this model the stats are resettable ... but you must defluff and clean the whole unit as something has made the stat trip usually a blockage somewhere
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint TDC62P Condenser Dryer no heat
Hi
Re your on going prob with dryer.
You should be reading 240v at the heater and stats.
To be sure the stats are faulty or not, you need to remove the connections to them and test for continuity through them both.
Set you meter on the ohms range, you should get full scale deflection if they are o/k
if you do not get a reading, then they are faulty.
The orange wires should be on the left side stat, and the blue on the right side stat.
It is possible you have got the stats the wrong way round, the one with the green spot on should be on the left. They are rated at 130c for the green spot,and 106c for the other one.
To be sure you have the right stats, the partnumber should be 1701774.
It is imperative you have the right ones fitted, as they changed the part number depending on the date code of the dryer.
If the stats are o/k then it is possible that the pcb is faulty.
Hope this clarifys things for you.
Good luck.
Dec 20, 2008 | Dryers
Hotpoint tdc62p changed thermostats as blowing out cold air,
Make sure that all filters are properly cleaned, and that the air inlet and outlet vents are clear. Make sure water container is empty.
The best way to clean the filter at the bottom is to run cold water through it, this will clear out all the lint.. Make sure you have the correct stats ( there are many for the hotpoint range) and that you have them in the correct position on the heater back plate.
Plz rate this solution.
thanks.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
I have a hotpoint TC71 condense dryer and the stats are gone (as there is very little heat coming from the dryer) Which stat do I replace? The one on the right or the one on the left?
The stats come as a pair, so replace both of them ,even though only one has gone.
Make sure that all your filters are clean, and that all air vents are clean and clear..
This is a common cause of stat failure.
Thanks.
Dec 16, 2008 | Dryers
Hotpoint condenser dryer ctdoo
water pump at the back of the machine at the right hand bottom corner has either been blocked up with gunge which can me easily cleaned or the pump is not pumping, replace the pump
Aug 24, 2008 | Dryers
Condensor hotpoint ctd80 drier WON'T GET HOT
Check vent from dryer to outside.
May 09, 2008 | Dryers
Not drying
Is it still under warranty? I've read that these machines are better left at the retailer...
Dec 08, 2007 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
59 people viewed this question
Top Dryers Experts
