Question about Samsung SGH-D900 Cellular Phone
Very short battery life. I have replaced the battery twice and the new batteries last no longer than the original in standby........about two hours before the phone shuts down....how might I down load a repair to the phone soft ware
    Scholar:
  • 51 Answers
Hi!
It sounds like there may be a possible hardware fault with your phone if it is draining that quickly (if it's under warranty, you can return it for a replacement). Though if for some reason your phone thinks that it is actively in use all the time, a software (or firmware) update may possibly fix the problem.
You could try performing a factory reset of your phone's settings by going to your Menu / Select Settings / Select option 9 (Reset Settings) / Reset All settings.
Failing that, contact Samsung Technical Support on 1300 362 603 & ask them to repair/upgrade your Firmware. They can do this over the network without you having to do anything in most cases. Otherwise they can walk you through doing it via a USB connection to your computer.
Warning though..a firmware upgrade will more than likely wipe your phone's memory of messages/address book etc so back these up first. I would also highly recommend using Samsung or a registered professional to do a firmware upgrade as doing it incorrectly can turn your phone into an expensive paper-weight.
Hope this helps.
Posted on Nov 19, 2009
Testimonial: "Thank you for your reply. I will certainly try to get Samsung to supply me with the number you suggest although they failed to respond the last time!"
  • B00ndock
    B00ndock Nov 19, 2009
    Sorry, that Phone number for Technical support is only if you're in Australia. You can get the correct phone number from the "Contact us"section of the Samsung website www.samsung.com
I have a nextbook 7 or 8 tablet. it no longer charges in any way, and it gets extremely warm when connected to a charger no mattet how short a time it is plugged in for.
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Jun 07, 2014 | Tablets & eReaders
Hi my battery only lasts up to an hour, how do i
Well it should last between 3-4 hours if new. <br /><br />Batteries need conditioned . You fully charge them and then run them fully down. 1 hour seems pretty short. As a rule, don't run them on battery while plugged into power.<br /><br />I have no better solution than this.<br /> <!-- from fixya rte -->
Aug 17, 2010 | HP Pavilion zd8000 Notebook
Battery Life is VERY short. refuses to last longer than 10 minutes on its lowest power setting. Why is this happening? Does this happen with them all?
No generally Sony VAIO battery should last upto 1.5-2 hrs ..So your battery needs to be replaced ...
Thank You..
Dec 03, 2009 | Sony VAIO VGN-N250E/B Notebook
I unlock my nokia n73 but the phone keep switching itself off during useage or after couple of hours on standby. What can I do?
Call you Service Provider and find out if there is a common problem with the particular model and its battery going flat, as this happends with many Nokia N95s. There could be a fault with your battery,
or what u consider small usage could actually just be the expected battery life for the phone, confirm this in the Manual.
also try - http://www.walkernews.net/2007/06/08/converse-nokia-n73-battery-to-standby-longer/
for some tips on making the battery life last.
May 31, 2009 | Nokia N73 Cellular Phone
Short Battery life, Randomly shuts down, and more...
sounds like the battery is shot. Get a new battery and fully charge it. I try to charge my phone more off of a power outlet and not the cigarette lighter in a auto. The battery will last longer that way. something about cigarette lighters. As far as the messaging and failed calls goes. up grade your tower signals. contact your cell phone company and get the number for upgrading the towers.
May 24, 2009 | Pantech Duo Smartphone
My Dell Inspiron 1520 seems to use a lot of battery power, even when the lid is closed, and nothing is running. Is there any way to save battery power, without going into standby mode, or turning off the...
How long does your battery usually last? If it lasts 2 hours or more, that's normal for a notebook computer. The standby mode and turning off of hard drives is what notebooks are designed to do to give you more battery life. If you have to have it on and available all the time without going into standy mode, you'll need to get used to charging it every couple of hours. If you want to get more battery life, try the following options:
1) have the display turned off when not in use (this setting can be changed where you set up your screensaver)
2) turn off the wireless function (if available) when not in use
3) have the computer go to standby mode after 10 or 15 minutes of inactivity.
4) lower the brightness of your display
All of the above assumes that you're getting a decent charge and can use the notebook unplugged for 2 hours or more. Naturally, over time, notebook batteries wear down and don't hold a charge as well as they once did. If your notebook is a few years old and you're only getting an hour or so on a full battery, then it is probably time to invest in a new battery. If your notebook is new and you are getting this short battery life, contact Dell for a replacement battery as yours may be defective.
One last thing about notebook batteries. They are designed to be charged up and run down. If you leave your computer plugged in to a/c power all the time while you are using your computer, this greatly speeds up the wearing down of the battery. Whenever possible, you should fully charge your battery and then run the battery down to 10% or less before plugging it back in. This ensures that you get the most battery life on a consistent basis.
Hope this help. Please take a moment to rate the solution. Thanks.
Mar 11, 2009 | Dell Computers & Internet
Extremely short battery life
do you use alkeline batteries? if yes then they would end in 20-25 shots. Instead, use rechargable batteries of 2500 mah which will last long, very long. On my Cybershot H1, they give aproximate 350 shots with single recharge.
Go for Sony Original Batteries or Uniross brand also works fine.
2300 mah/ 2500 Mah any will work.. :-)
Nov 25, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Short battery life
Try running the battery down completely (0% so it turns off itself), and charging whilst the phone is completely off (I'd suggest leaving it overnight). Repeat this once or twice, then see if your battery life has improved. Also ensure that you havent left anything on that could be eating your battery up i.e. bluetooth, and contact your supplier if the problem persists, as you should be covered.
Aug 28, 2007 | Samsung SCH-u540 Cellular Phone
Battery
If you take a look on the back of your battery, it will give you a mAh value ie 1550mAh, the higher the number, the longer it will last.. most replacement batteries are 1550mAh, and very cheap, but you can get 3000mAh batteries, which should last twice the time, but they´re as much as 5 times as expensive... they obviously take longer to charge too..
Sep 08, 2005 | HP iPAQ H5550 Pocket PC
Samsung SGH-D900 Cellular Phone Logo
161 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
