Question about Sony KV-36FS100 36" TV
Sony kv-36fs10 sound but no picture
  • kelseee Sep 24, 2008
    sound but no picture!
  • Anonymous Mar 27, 2009
    cannot see any picture, but has sound on a couple of channels
    Problem Solver:
  • 5 Answers
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!!
Posted on Apr 13, 2009
It is connected to cable, which worked on my other tv. The menu will come up and and I can see the volume bar and the bottom of the screen, but still NO picture.
Posted on Sep 24, 2008
    Novelist:
    Scholar:
  • 148 Answers
COuld be a power supply issue or the way you have it cabled.
What are your inputs?
Posted on May 01, 2008
4 Suggested Answers
  • 346 Answers
SOURCE: sony trinitron kv-36fs10
video processor malfunction
Posted on Dec 22, 2007
  • 84 Answers
SOURCE: KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Posted on Jun 15, 2008
ripleymojica
  • 643 Answers
SOURCE: sony KV 36FS10 led light flases, no picture, sound is ok.
unplugg from wall and surge leave for 2 hours. if problems still there. your power supply is probably done. repair is usually pretty reasonable.
Posted on Jun 04, 2009
Sony KV 36FS10 led light flases, no picture, sound is ok.
Jun 04, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Help!! NO PICTURE/SOUND
The 'pop' may have been an arc of electricity from the flyback coil. The flyback is the device that produces very HIGH VOLTAGES --that can kill so be careful--. It may have just goten old and the material around the flyback broke down and allowed the electricity to arc to a near by source to ground. it happens when CRT sets get old. Typically I expect 7-10 years of a consumer grade CRT. Other then that any fix for it would have to be performed by a trained technician because voltages can linger in the 'caps' and even the 'tube' itself for years, I once got 'bit' by a set that was left un-plugged for 5 years.
Aug 15, 2008 | Sony KV-36FS100 36" TV
Intermittent picture on Sony KV-36FS10 TV
This is possibly an indication that the picrute tube is starting to fail. To confirm this, open up the back and carefully turn up the screen control just a bit. This is the upper control on the flyback transformer (part with large red wire coming out the top). Turn it only slightly clockwise. If the picture remains on, this suggests that the tuvbe is starting to fail and you will have given yourself enough time to find a replacement. Please note that this is not a permanent fix.
Keep us posted.
Dan
Jul 12, 2008 | Sony KV-36FS100 36" TV
KV 36FS10
To have someone come to the house to repair you are looking at usually $75 service call plus $100 labor plus parts. If the circuit board needs to replaced it could be up to $200 to $300 for the board if it is still available, sony is going flat panel these days and parts for your set are fazing out. If you take it to a shop you will save money on pickup and delivery and make it easier for the tech to diagnose which should save you money.
Jun 16, 2008 | Sony KV-36FS100 36" TV
Jun 15, 2008 | Sony KV-36FS100 36" TV
Sony trinitron kv-36fs10
dear misskona, I suggest that if you have any technical knowledge the first thing you do is to increase the screen voltage and see if there is a bright line across the screen solder the vertical I.C or remove and fix another working one.if that do not solve the problem there is scat board solder some dry joint.
thanks
Dec 21, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No picture, but has great sound
Older television have components that are designed to last for about 10 years. slight movements can cause failures in old Capacitors and loosen connections.
Might sound weird but seriously give the thing a good slap on the side after it has warmed up. if there is any effect AT ALL. take it to a repair man. if not your set may have simply bit the dust and now requires more servicing costs then a new set.
Nov 07, 2007 | Sony KV-36FS100 36" TV
Dopped tv, worked fine, now not picture but has sound
Most drop damage is in/around the area of the flyback xformer.My Motto==PVAT! With magnifier examine PCB for crack(s).May still be fixable.
Jul 31, 2007 | Sony KV-36FS100 36" TV
Sony KV-36FS100 36" TV Logo
221 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
