Question about SNK Knight 43AW Electric Dryer
My tumbel dryer is making a hugh banging sound when it is in use, it is drying fine, just the noise.
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
Gas dryer making banging nosie when drying
could be broken spring on suspension or broken tentioner wheel around dryer tub
May 05, 2012 | Frigidaire Dryers
When drying clothes, there is a loud banging noise, almost like if the clasp to overalls is hitting the inside of the dryer. Right now I am drying towels, so there is nothing metal or hard that could be...
Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a banging sound. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks.
Check to see if the drum is supported on wheels or rollers. Sometimes these can wear and require replacement.
Good luck and have a nice day
Jul 03, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
Mar 07, 2010 | LG DLG5988 Gas Dryer
Dryer makes banging noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
uioiotusdds
Jan 30, 2010 | GE DBVH512GFWW Dryer
Maytag dryer making a loud banging sound
are there shoes in the dryer?is the dryer level?
Aug 16, 2009 | Maytag PYE2300AY Electric Dryer
Dryer is working but wont tumbel
This does sound like the belt has broken. Is the Defy autodryer the one that made the sound and then stopped tumbling?
Nov 11, 2008 | Dryers
sounds like another problem occured causing your belt to either break or slip off the motor
Oct 25, 2007 | Kenmore 98702 Stacked Washer/Dryer
SNK Knight 43AW Electric Dryer Logo
51 people viewed this question
Top SNK Dryers Experts
Dan Webster
Dan Webster
Are you a SNK Dryer Expert? Answer questions, earn points and help others
