Question about Panasonic TX-32LXD1 32 in. LCD Television
Hi I have a Panasonic LCD TX-32LXD there appears to be a line across the screen. It is about 1" 1/2 wide. but is completely see through and depending on what colours are on the screen depends how bad it is. It seems to appear more when there is a lot of light colour on the screen. Some one actually has said it looks more like an indent mor than a line like some one has left a ruler behind the screen when it was built but it was not like that from new and the screen is completely flat. It doesn't spoil the picture just is a bit annoying. Any ideas if it can be fixed and what I would need to do ?
  • 92 Answers
Hi There,
Try restore the tv to factory state. It could be a burn in from a tv station you always watch eg. Some lcd will have a non burn in function, What that means simply is if you watch mtv all the time it will leave the mtv sign in the corner as its burned into the tv. Depends on how old the tv is restore and see what happens from there, other than that get an engineer or replace it if its still under warrenty....Hope this helps
Posted on Nov 17, 2009
I have a 2011 Panasonic plasma tv I bought new in 2011 and today there is a red/blue stripped line 1-1.5 inches wide across the top and a dotted green/purple line 3-4 inches below the blue/red line.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 17, 2017 | Panasonic Televison & Video
Lines across screen appeared after the SN Board was replaced.
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 06, 2016 | Panasonic Televison & Video
Panasonic TX-P42521B has a red/blue band across the screen (about2" wide) which is flickering and about 2" below is a broken red line. Any ideas? Thanks.
These symptom seems to be caused by a
defective D or SC board but in reality, they are
caused by a defective SD board.
To confirm this, disconnect the SD board from
the SC board (Follow proper SU/SD board
If the SD is defective, the screen will have a good picture at the top half of the screen and a completely black area in the lower half of the screen.
R
Jul 21, 2014 | Panasonic Televison & Video
Faded section of screen
Is it an LCD or plasma monitor? If it's an LCD, it's possible that one of the fluorescent backlight tubes is bad. In some early ones, this is bonded to the LCD panel so it's not replaceable. Maybe it's under warranty?
Jul 18, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Need to reset owner ID on a panasonic tx-32lxd
Service Mode Function
MPU controls the functions switching for each IICs through IIC bus in this chassis. The following setting and adjustment can
be adjusted by remote control in Service Menu
How to enter SERVICE
In main menu, move to choose sound menu, set BASS to MAXIMUM, and set TREBLE to MINIMUM.
Simultaneously press " i " button on remote control and DOWN button (-/v) on the TV set.
Exit with off switch on tv.
When you next switch on TV it is as brand new giving you the option of setting pin number and user ID.
Mar 05, 2009 | Panasonic CQ-VD7500U 7 Wide LCD/DVD/SD/TV...
Blue lines appear across screen during video playback.
thank you for choosing Fixya.com.
it seems that some parts in your Cam are Dirty.
please try to use the head cleaner disk first.
let me know if any changes happen.
goodluck
please don't forget to rate our answers properly.
Mar 03, 2009 | Panasonic Palmcorder PV-GS12 Mini DV...
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Panasonic TX-32LXD1 32 in. LCD Television Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
