My Dell XPS-M1530's 90W-AC Adapter beeps and doesn't work
My Dell XPS-M1530's 90W-AC Adapter gives a beeping sound from inside and does not give an ouput. It used to work after tapping on the sides, for a while. Now that it only beeps and not works I cut the enclosure open (since it is ultrasound sealed) only to find that the +VCC and Ground lines are short! Now I would have suspected a short capacitor but the resistance drops to almost 0.2ohms from 7ohms within 3 seconds. A normal capacitor would have shown the opposite of this response (increase in resistance with time). Is this a common problem with Dell adapter? Since I am no electronics expert, i couldn't go any further. Please advice
Omg!!!!! your going to die!!!!
Posted on Nov 07, 2010
    Novelist:
  • 225 Answers
Thi might affect the XPS system performance. Please have AC Adapter replaced.
Posted on Dec 11, 2009
Dell Inspiron N5010 4 beep error
This may help. The 4 beep code error in Dell Inspiron N5010 mean Memory read / write failure. Try draining the residual charge and check if you are able to boot. Here are the steps:
  • Disconnect any external peripherals (flash drives, printers, external hard drives) from the computer including the battery and AC Adapter.
  • Press and hold the power button for 20 seconds.
  • Reconnect the battery and the AC Adapter. Try to restart the computer and check.
Please make sure that the memory modules are firmly reseated and there is no dust accumulated on the memory slot on motherboard.
May 20, 2014 | Dell Inspiron Computers & Internet
Beep problems
Possible faults:
1.The battery has no power.
2. AC adapter loses energy (need test it)
Remove the battery and turn laptop directly from AC adapter. OR, try to turn the battery directly without AC adapter.
if the signals are repeated then most likely have to replace the AC ADAPTERghj,
Oct 06, 2013 | Dell OptiPlex Computers & Internet
Blinking yellow light on xps200. changed power supply. still blinking yellow
A blinking yellow light means that there is something wrong with the motherboard, if not the motherboard itself it will be either the RAM, wiring connections, bad processor or it may need a fresh coat of thermal paste on the processor itself. With Dells, its pretty easy to find out. Start the pc and You will hear some beeps count the beeps. ex:beep.beep...beep.beep which gives You a code this one being 22. Once You get the code go to Dell support and look up service code and it will tell You what the problem is. Good Luck.
Nov 10, 2011 | Dell XPS 200 PC Desktop
I have a Dell XPS 600 desktop computer. I cannot get the power to stay on. None of the diagnostic lights light up. I have checked all of the connections and everything is secure.
Here's what to try: Disconnect everything from the motherboard except the CPU and memory. You may leave the video connected to see what, if any, error message you might get.
You didn't say if you got any beeps on startup. They can tell you what might be the problem.
If this doesn't work, remove the memory modules. The power should stay on but you'll probably get either a steady beep or a bunch of little beeps. (I don't have the Dell error codes close at hand at the moment).
If this doesn't work, you have narrowed the problem to one of three things: The CPU, the motherboard, or the power supply.
You didn't mention just what happens when you turn it on--just that it won't stay on. Error messages are helpful if you get any on the screen as are any beep tones.
Jul 21, 2011 | Dell XPS™ 600 PC Desktop
Dell xps 420, won't finish loading bios boot screen, freezes and gives steady fast beep,cant get into safe mode, no clue what to try
see if this info helps narrow down the failure
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Apr 03, 2010 | Dell XPS 420 PC Desktop
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
Dell XPS 600 beeping noice
there are 2 things that can cause that, memory failure, or mother board, cheeper route to go would be replace your memory first, and see if that corrects the problem, if not then, check anything new you installed inside such as video card, lan cards, of something like that, if that doesn't work you need to have it looked at and possibly the mother board replaced,
Jun 22, 2009 | Dell XPS™ 600 PC Desktop
Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Computers & Internet Logo
1,546 people viewed this question
David Payne
David Payne
