Question about Refrigerators
We have water leaking from the bottom of the fridge and the ice make is not working. How do I shut the water off? Viking two door
  • Refrigerators Master
  • 2,122 Answers
Find out where the water line is tapped into maybe under the sink,follow the water line and you should find a shutoff,also lift arm up on ice maker if it is making noise,for the water leaking,you could have a blocked drain inside freezer,at the bottom of the back wall there is a drain if it is blocked water will leak out at bottom of fridge,melt it out with hair dryer and clean out drain,i use a steamer but if you don't have one make some kind of a snake to clean out the drain,pour hot water down drain to see if you cleared it
Posted on Nov 17, 2009
  • 92 Answers
Hi There,
You need to find the mains water supply into the house and shut it off. Or you could check the back of the fridge and see if ther is an isolating valve..Hope this helps...Please let me no
Why is my Viking refrigerator/bottom freezer leaking water out bottom of door? There is a layer of ice on bottom of freezer.
The ice on the bottom of the freezer is blocking a drain hole. When the freezer defrosts automatically, water drains out the bottom into a tray, where it evaporates away and you never see it under most conditions.
The solution is to either defrost the freezer manually and let the ice melt, or pour some hot water into the bottom of the freezer to thaw out the ice and clear the blockage.
If the drain is plugged because of some foreign matter, either method will make a mess, so have some towels at the ready to sop everything up if need be. If it is blocked, a can of Air Duster (like for cleaning electronics) might be able to blow the blockage out, if you seal the nozzle tube up as it is stuck into the drain.
Most likely it is just ice blockage.
You can access the drain tray (where the water goes to evaporate) by removing the grille on the front bottom of the fridge and peeking / poking around. You might want to keep an eye on it as you defrost the freezer or pour hot water in the bottom - it can over-fill quickly.
Jul 20, 2014 | Viking Refrigerators
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Water leaks under viking professional and there is about a 1/4 inch build up of ice on floor of freezer(which is on the bottom) on the floor of the pull ot freezer
Your drain is plugged. Basically the freezer goes into defrost and melts frost off the condenser coils. A big piece most likely fell off and freezer came out of defrost before it coulld melt and drain out completely. To fix you have 2 options. Have towels
#1- move contents of fridge and freezer to a backup fridge. Leave unpluged with doors slightly opened for 24 to 48 hrs. Use towels to cleanup any water. Plug back in wait 2 hrs to make sure temp gets back down before putting contents back in fridge.
#2- Remove contents from fridge and put in ice chest. Have towels ready. Remove ice maker ( if there is one) usually two screws on top hard to see and one on bottom. Disconnect the quick connect for the ice maker. Remove screw on back wall. Be careful when removing air vent on back wall. Its plastic and can break. Remove back panel. Look on the silver plate under coils and you will see ice and where the drain is. Remove ice than pour hot hot water down drain until it flows freely into drain pan under fridge by compressor. It may look like there is not ice make sure othyerwise you will be doing this all over again in a few days. Once water flows freely put everything back together wait about 2 hrs for freezer temp to get cold enough and than you can put contents back in freezer. If you have any question or need help please feel free to comment me back.
Jun 05, 2011 | Viking Professional Series VCBB36 Bottom...
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Leaking water from the actually fridge over the floor.
manually fully defrost unit,clean all vents /drain pipes
make sure door seals touch all round(no air gaps)
use bicarb to freshen interior and dry as best you can
then switch on and hopefully,if unit is working normally,enjoy...only place cold food in fridge to minimise ice build up.(some fridges have a drain vent in the centre bottom of door to allow water to drain when defrosting
Feb 14, 2010 | Refrigerators
How do i turn my ice maker off? i have a viking side by side and the ice maker is just pouring water in my freezer...its a mess!
Turn the water off under the sink where the small line starts that goes to the fridge or there may be a cut off directly behind the fridge in the supply line.
Your water inlet valve may be stuck open. It's where the water supply connects to the fridge.
Dec 11, 2009 | Viking VCSB423 Side by Side Refrigerator
Water lks bottom of fridge ,also ice tastes horrible
u shd spl ot ur wds fly. Do you mean the water leaks at the bottom of the fridge? If so, you may have a clogged drain hose. Pull out fridge, disconnect power, check & see where drain comes out of fridge, go to front and pour hot water down drain to see if it is frozen. It may be clogged (pea or food). If the drain doesn't work, the fridge will leak. Check the gasket on the fridge door for sealing and make sure it is in good shape.
Oct 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Ice maker not working/ water leaking from bottom
turned out the filter had a leak. So first shut of the water valve that made the connection to the fridge then twisted the filter counter clockwise and replaced it with a new filter.
Jan 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Jan 01, 2009 | Viking 42 in Built In Professional...
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
