Question about HP Pavilion dv6000z Notebook
Windows off, it makes noise whenever it is on, cannot be on,,
Windows off, cannot be switched off, unless the battery is removed, make noise when it is on.
    Scholar:
  • 174 Answers
First check your switch is working fine press and hold the switch for a long if it now getting switched off motherboard is the problem.
Posted on Nov 19, 2009
Where is the power window relay located on a 1964 Pontiac GTo with AC.
I believe those older cars used circuit breakers, not relays, for the power window systems. By using a test light, you don't know if battery voltage is present at the window switch. Maybe the voltage is reduced, somehow.
I would first check the switch's power with a voltmeter. If the motor is getting battery voltage, I would say the motor. If the voltage is low,
you had better find a wiring diagram, Dave, to trace it out.
Oct 25, 2014 | 1967 Pontiac GTO
Hp altec lansing makes a beeping sound while starting
Try running a registry cleaning program. That should sort the errors out
May 20, 2014 | Acer Computers & Internet
Window motors sounds
It sounds like the power locks are making the noise to me. First the power going to the window gets shut off when you shut off the key. Second the window will not make noise unless the cable for the window regulator is broke, then the window will go down and stay down or up and wont go much of anywhere. Try to hold the power lock button and listen for the same noise. Most of the time the one of the switches go bad and keep trying to lock the car. Its usually the one that wont lock or unlock.
Feb 02, 2014 | 2005 Chrysler PT Cruiser
Whistling sound upon acceleration
Tyres, brakes, turbo, transmission, axle ...
Jul 06, 2017 | 2000 Jeep Grand Cherokee Limited
Noise of 2004 Volvo s40 2.4i
Cannot figure out what that part is, but it has a vacuum line connected. Therefore, it should not be functioning unless the engine is running. I would have to guess there is a wire crossed in the key cylinder. The presence of the key should activate the warning system and perhaps deactivate the security system. However, the engine system wiring comes in proximity to the warning wiring behind the ignition switch near the contact reel. It's possible you have a short in that area. I am posting access instructions from autozone.com.
CAUTION Models equipped with a Supplemental Restraint System (SRS), use an inflatable air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column, and instrument panel, disable the SRS.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect battery cable.
  3. Remove steering wheel and air bag module. Refer to Steering Wheel removal and installation.
  4. Remove steering column covers. Remove or disconnect the following:
    Screws from lower coverClip mounting between the upper and lower coversLower steering column coverUpper steering column cover
  5. Remove the contact reel:
    1. Disconnect the left connector.
    2. Remove the screws.
    3. Remove the contact reel.
      Fig. Removing the contact reel from steering column
  6. Remove the ignition switch:
    1. Disconnect the electrical connector.
    3. Remove the ignition switch.
      Fig. Ignition switch removal
To install:
  1. Install the ignition switch:
    1. Position the ignition switch and tighten the screws.
    2. Connect the electrical connector.
  2. Install the contact reel. Tighten the M5 screws to 44 inch lbs. (5 Nm).
  3. Install the upper and lower steering column covers. Tighten the screws.
  4. Install the air bag and steering wheel. Refer to Steering Wheel removal and installation.
  5. Connect the negative battery cable.
Jul 15, 2017 | 2004 Volvo S40
Whenever its time to take photos, the camera makes a wierd noise and the focus lens do not shoot out as normal,what should i do???
When a camera makes a noise that isn't normal, usually it's a mechanical failure of the lens.
Remove the battery for a few minutes and turn the camera on and attempt to take a picture again.
If it doesn't work, I can venture to guess that the camera's lens mechanism is defective.
Mar 05, 2011 | Samsung S760 Digital Camera
The in dash emergency flasher button which i think is also the signal light flasher makes annoying clicking noises whenever it likes
The computer system is constantly doing self tests. Unless you note a problem when it clicks, I wouldn't worry about it. If it is annoying then you may want to have a mechanic take a look at it. Good Luck
Jun 02, 2010 | 2001 Pontiac Grand Am SE
Casio WK 3200 keyboard makes funny noise
removed batteries, reinstalled them, resetting keyboard, problem solved
Jan 08, 2009 | Audio Players & Recorders
Air conditioner compressor
buy a a/c bypass pulley.you'll won't have a/c no more though unless u buy a new compressor
Jul 03, 2008 | 1996 Chevrolet Corsica
HP Pavilion dv6000z Notebook Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
