Question about NEC NR 7900A (NR7900) CD-RW Burner
My NEC CD-RW NR-7900A is not reading any cd plz tell me any solution contact:Johnmaster_28@hotmail.com
  • NEC Master
  • 6,993 Answers
Check the lens, maybe it is weak....
Take care
Posted on Nov 17, 2009
SOURCE:
Will this burn dvd
No, it will only burn CD's. You need a DVD-RW/DVD-R burner.
Jan 24, 2011 | NEC NR 7900A (NR7900) CD-RW Burner
Pc freezes when I click open on my nec nr 7900a cd-rw. dell pc, software windown xp,
this is most likely an interface issue either on the motherboard or drive....could be software but dvd drives don't last forever. when booting press delete and let it go into bios setup. You don't need to change anything in bios, just try opening the drive. If it opens without delay remove any disc. Reboot PC and see if the drive behaves, If it's still being awkward, with the PC unplugged open up the PC and remove the drives data cable. Start PC, close down PC. Reconnect drive (use a different IDE /SATA connection if possible) Try DVD drive again. If the fault still persists, It's most likely the drive. Get a new one they are really cheap.
Aug 02, 2009 | NEC NR 7900A (NR7900) CD-RW Burner
CD-Rom drive missing
Go to this webpage and you will be able to solve the problem. http://support.microsoft.com/kb/314060#letmefixit Basicallly, you'll be resetting the registry to recognize your CD ROM again. Be SURE TO FOLLOW STEP BY STEP. Print the instructions first so that you don't lose your place.
Apr 09, 2009 | NEC NR 7900A (NR7900) CD-RW Burner
I have a NEC NR 7900A music burner that came with my dell
It Sounds like you need a CODEC, to DECode the movie, so that it will burn it. Try this: goto http://www.dvd43.com download the decrypter. Install it, and you should be able to burn most, if not all the newer DVD's.
Let me know if this does not work for you. If that happens, let me know what version of Windows you are using
Dec 20, 2007 | NEC NR 7900A (NR7900) CD-RW Burner
Drive will not work at all
You may need to disable CD autorun feature. What version of Windows do you have?
Nov 09, 2007 | NEC NR 7900A (NR7900) CD-RW Burner
My NEC NR 7900A burner will not burn music cd's or photos
i try to burn music from my libery with but i get a massege that says i need to instole my cd burner can you help me with this
Oct 31, 2007 | NEC NR 7900A (NR7900) CD-RW Burner
Wont recognize burned disks
This does sound like a defective drive, most likely a laser / reader issue, because the refractive properties of the CDR is different from a "pressed" disk it looks like thia failed TOC seek issue, the head starts at the center of the disk and reads outwards, the click noise is most likeley the head reaching the terminus (the outer limit of the motorised movement), the drive then unable to find the TOC gives up and decides the disk is unreadable. if this drive is within the manufacturer's Warrantee period I would reccommend sending it back.
Apr 25, 2007 | NEC NR 7900A (NR7900) CD-RW Burner
NEC NR 7900A (NR7900) CD-RW Burner Logo
347 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
