Question about Microsoft Video Game Consoles & Games
1 red ring E68 - Microsoft Video Game Consoles & Games
    Problem Solver:
  • 16 Answers
The single red light on the Xbox shows that there is a hardware failure.
The E68 error is linked to a problem with the Xbox 360 Hard drive. Try removing the hard drive from the Xbox and attempt to use the Xbox again.
If the error does not occur when the hard drive is not connected then you will need to replace the hard drive.
If the error still occurs then the console will need to be repaired.
Posted on Nov 18, 2009
2 Suggested Answers
ZombieEmily
  • 60 Answers
SOURCE: e68 red ring
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
Posted on Jan 29, 2010
My son has an Xbox 360 slim 4g. I bought him a 320 g Xbox HD. When I install it and turn the system back on I get the red ring and an e68 error. When I remove it it works fine. Please help thanks.I have...
This is called the red ring of death, what I have researched try taking all the memory devices out (hard drive, any usbs, the expansion memory etc...) turn the Xbox on wait for it to boot up once booted turn it back off, make sure all connections for the memory devices are clean reconnect the memory devices to the Xbox and turn it on this should get rid of the RRod error 68.
Sep 08, 2013 | Microsoft Xbox 360 Console
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
I was watching net flicks and my xbox rebooted and flashed a red ring (bottom right) and it said E68. i shut it off and started it up again and works<did that twice<the unit was alittle hot...
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
To fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft, as the e68 is generally believed to be related only to your console's hard drive/HDD.
Hope this helps.
Mar 06, 2011 | Microsoft Xbox 360 Console
One red ring, erra 68.
What you need to do is try using the console without the hard drive or with a different hard drive, one red ring means a hardware failure, and the error code e68 is in relation to the hard drive. If using the console with a different hard drive, or none at all doesnt work, ensure that the fans are working as they often also cause the e68 error and a single flashing red light.
I hope this helps. Good luck.
Sep 03, 2010 | Microsoft Xbox 360 Console
My xbox360 has the 3 red rings and it say e 68
Hi not sure if this helps had e68 on some I have repaired and sometimes it turns out to be the harddrive just unclip the hdd from the side and turn it on without it good luck
Mar 27, 2010 | Microsoft Xbox 360 Console
X box360 flashing red light
Where is the flashing light? If it is at the 3rd position (bottom right) only, then the screen should say E68 error. If this is true, turn off the system, take off the harddrive, put the harddrive back on and turn the system back on. This happens to mine frequently. If its 3 of the lights, then you are out of luck my friend. Red Ring of Death...
Feb 19, 2010 | Microsoft Xbox 360 Console
E68 red ring
Jan 29, 2010 | Microsoft Xbox 360 Console
E68
www.llama.com
Good info for 360s
Jan 26, 2010 | Microsoft Xbox 360 Console
Got system error E68-and a red light-this has happened after using a hard drive to save my game data-now can't find any data-would appreciate assistance!!!
I've got a permanent fix for Error E68 to help you out, But first ill tell you my XBox was dropped so it might have just worked for mine, i will be posting a vid on youtube by Nov. 5 2009 look for imthatstupidkid fix X Box Error E68 walkthrough
Oct 20, 2009 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
1,068 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
