Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
The pictures zoom beyond screen hence cutting some words/pictures when on video input mode, otherwise it is ok with tv mode!
    Scholar:
  • 86 Answers
Hi and thank you for reading my input. i would go to my menu screen and try to adjust my zoom. i would also see what mode it is on such as cinema,natural,etc. this should solve your problems. thank you and please rate my solution.
Posted on Nov 17, 2009
Picture on 47
You do not worry at all, because the set is under warranty.
Launch a complaint and sit peas fully.
Jul 23, 2012 | RCA 47LA55RS 47 in. LCD TV
My tv screen is too wide horizontally. I can't see but what's in the middle of the picture. Do I need to purchase a new tv or is this something that can be fixed?
go into video set up and take tv out of zoom mode
it sounds like you have it set to zoom a standard definition signal and that will make picture become bigger than the screen and cut picture off
hope that helps
Mar 25, 2011 | Polaroid TTM-2401 TV
Picture seems to big for TV.cant read bottom words on screen and words are cut off on side also. Cant see scrores on any sports or read peoples names on bottom of the screen
Using the menu or settings button on your remote, access the TV's menu and find the area for picture settings and zoom. You're likely set to a zoom mode, so cycle through the options until you find the zoom setting that sizes to your TV best. (On most widescreens, the best picture is often on the setting 'panarama.'
Mar 12, 2011 | Vizio L37 Television
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Check to see if you are on wide zoom mode in that input and check the definition. Go to your menu screen and check your video menu. There are different options for viewing. My inlaws prfer the words cut off it drives me crazy. Hope that helps
Apr 26, 2010 | Proscan 42LA45H 42 in. LCD TV
Heads are cut off off
It sounds like you may have the zoom mode enabled on the TV source. A lot of HDTVs have settings for how different modes like 4:3 format source video is displayed such as Normal, Full, Wide, Zoom and Wide Zoom. Each signal input may have a different display mode and that is why DVDs look ok and TV does not. Not all TVs have that feature but most of the ones that I have dealt with do.
It may also be a screen centre adjustment in the cable box or satellite receiver.
I hope I was able to give you a viable solution.
Cheers
Jan 04, 2009 | RCA R52WH73 Projection Television
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Xbox picture gets cut off on the sides
try fiddling with the tv menu. most tvs have the zoom function now and also the ratio function. try testing those configurations starting from the default. make sure you have the zoom function set at 0 before fiddling with the ratio aspect.
Aug 14, 2008 | Samsung TX-R3075WH 30" TV
Picture larger than screen...
If you go to 4:3 mode and the picture is still cutoff then i would assume the tv has a problem with the horizontal or the pinchusion correction circuit . This would be the only two areas that would cause this problem . Check the format section of your menu to make sure it is not in zoom mode or otherwise if it is not then you have a problem with one of two above mentioned circuit problems . Good luck
Feb 01, 2008 | Sanyo DS31520 31" TV
Panasonic plasma
go in to your tv's menu and go in to picture settings , you either have the zoom function on or its been set on 4:3. check these and if zooms on turn it off or if 4:3 is on switch to 16:9
Nov 28, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
134 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
