Question about Exercise & Fitness
Error 03 (E03), on my P4 Motorized Treadmill With MP3 Link.
    New Friend:
  • 64 Answers
Not sure what error 03 means for this brand. What is the mill doing or not doing?
Posted on Nov 17, 2009
  • 2 more comments
  • raineybobs1 Oct 15, 2010
    i have a pro fitness motorized (cant seem to locate code for it) keeps coming up E03 whilst running and stopping instantly, has always started again straight away until today, when only starts again for a few secs and then stops again. The belt seems to speed up faster than the speed on the display? anyone have any ideas???
  • damcam18
    damcam18 Oct 11, 2012
    Hi, It starts up ok then about 2mins of use it speeds up on it's own and then shuts down with the error code E03
  • damcam18
    wow! this is exactly what my lifespan xcell is doing - did you find a solution?
  • damcam18
How do i fix my vfit treadmill error code showing on display error code 03?
If you wish to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Sep 25, 2016 | Exercise & Fitness
Shows an error of E03
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Precor Error Code 03 E03 EEPROM Test Error
Oct 03, 2015 | Exercise & Fitness
I have johnson jet 7000 treadmill and its showing error 2 what can i do
HI,
Error 2 means P0 P1 P2 P4 P5 ( P0 ....Min. ,Speed P1 ....Max, Speed P2 ....Mid.Speed, P4 ....Min.Slope, P5 ....Max.Slope )have a wrong parameter values. You have to go the engineering mode and set the parameter. Here i have added a link which will guide you to the service manual of Jet 7000. read the section 4 (console maintenance mode guide) and re-calibrate the treadmill parameters P0 P1 P2 P4 P5 .page no(4.3).
http://www.cross-ir.com/Downloads/JET7000-6000-1.PDF
WWW.electro-medical.blogspot.com
Sep 16, 2015 | Exercise & Fitness
Reebok z8 error E03
I can not adjust my tension on my machine
Feb 27, 2014 | Exercise & Fitness
Precor treadmill code e3 is on
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Lifespan fitness focus treadmill E03 error
repair the magnet wire, adjust the magnet and reset see the diagram attached.Clean it.
5_6_2012_11_28_07_am.gifsincerely. God bless you
Apr 21, 2012 | Exercise & Fitness
Carl Lewis MOTC66 E03 error HELP !
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
May 04, 2010 | Exercise & Fitness
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Exercise & Fitness Logo
749 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
