Question about Chicco C1 Trio Auto-Fix TS Iceberg Umbrella Stroller
Where can I get instructions for the C1 Trio and a new spring and adjuster for the rear wheel.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
Www.buggypitstop.co.uk can repair your chicco and get in touch with chicco in the uk and they will send you the instructions free of charge
Posted on Nov 18, 2009
Rear brakes
Removal
1.Remove rear wheel and tire assembly from vehicle.
2.Remove rear brake drums from hub and bearing assemblies after loosening the two brake drum screws.
3.Be sure that the parking brake pedal is in the release(most upward) position.
4.Completely loosen square nut of the rear parking brake cable. Then create slack in the rear parking brake cables.
5.Remove adjuster spring from adjust lever and brake shoe.
6.Remove adjust lever and turn the adjusting wheel of adjuster assembly to the direction of the arrow as shown.
7.Remove the strut spring and the lower retracting spring from the brake shoe.
8.Remove the upper return spring from the brake shoe.
9.Remove brake back plate hold down spring and pin from the leading brake shoe assembly.
10.Remove the leading brake shoe. Then remove the adjuster assembly, strut and anchor spring from the trailing brake shoe.
11.Remove the trailing brake shoe from the brake back plate after removing hold down spring and pin.
12.Remove the trailing brake shoe from the rear parking cable.
13.Remove parking pivot lever from the leading brake shoe.
Replacement
1.Lubricate the eight shoe contact areas on the back plate and anchor.
2.Install the trailing brake shoe to the rear parking cable.
3.Install trailing brake shoe on brake back plate and install the trailing brake shoe hold down spring and pin on the brake shoe.
4.Tighten the square nut of rear parking cable.
5.Install the anchor spring then install adjuster assembly, and strut.
6.Install leading brake shoe on brake back plate.
7.Install the brake shoe upper return spring, strut spring and the lower retracting spring to the brake shoe.
8.Properly rotate the adjusting wheel of adjuster assembly to the direction of the arrow in as shown.
9.Install the adjuster spring on the adjust lever and leading brake shoe assembly.
10.Install the leading brake shoe hold down spring and pin on the brake shoe.
11.Adjust brake shoes assemblies so as not to interfere with brake drum installation.
12.Install the rear brake drums on the hubs.
13.Check and adjust whether the pedal stroke in the specification.(Refer to section BR Gr./On-vehicle service/Pedal stroke of parking brake)
14.Install wheel and tire.
15.Push the parking brake pedal to the floor once and release pedal. This will automatically remove the slack from and correctly adjust the parking brake cables.
16.Test the vehiche on the road. The adjust will continue the brake adjustment during the road test of vehicle.
Inspection
1.Inspect the disassembled parts for wear, rust or damage.
2.Measure the thickness of brake shoe lining.
Standard : 0.17 in (4.5 mm)
Minimum : 0.04 in (1 mm)
3.If the shoe lining is less than minimum or shows signs of uneven wear, replace new one.
4.Measure the inside diameter of the brake drum.
Standard : 10 in (254 mm)
Maximum : 10.07 in (256 mm)
5.If the inside diameter of the brake drum is more than maximum or shows signs of uneven wear, replace new one.
6.Inspect the lining and drum for proper contact. If the contact condition is improper, repair it with a grinder or replace the brake shoe assembly.
Aug 14, 2013 | 2002 Kia Sedona
Instructions and diagram,to remove and replace rear drum brakes
1984 Ford Tempo - Rear Drum brake drum/shoes
REMOVAL & INSTALLATION
See Figures below instructions
1. Raise and safely support the vehicle with jackstands.
2. Remove the wheel, tire, hub and finally, the drum assembly.
3. Using a spring removal tool, remove the horizontal securing spring at the top first of the assembly.
4. Pull the adjuster locking plate away from the shoes.
5. Remove the lower horizontal securing spring.
6. Unfasten one of the 2 shoe hold-down springs and remove the pin.
7. Remove the brake adjuster.
8. Remove the remaining hold down spring and clip.
9. Lift the brake shoes assembly off the backing plate and wheel cylinder assembly. Be careful not to bend adjusting lever during the removal process.
10. Remove the parking brake cable from the parking brake lever.
11. Remove the horseshoe retaining clip and spring washer and slide the lever off the parking brake lever pin on the trailing shoe.
To install:
12. Apply a light coating of high temperature grease at the points where the brake shoes contact the backing plate.
13. Apply a light coating of lubricant to the adjuster screw threads and the socket end of the adjusting screw. Turn the adjusting screw into the adjusting pivot nut to the limit of the threads and then back-off 1 / 2 turn.
14. Assemble the parking brake lever to the trailing shoe by installing the spring washer and a new horseshoe retaining clip. Crimp the clip until it retains the lever to the shoe securely.
15. Attach the parking brake cable to the parking brake lever.
16. Attach the lower retracting spring to the leading and trailing shoe assemblies and install to backing plate. It will be necessary to stretch the retracting spring as the shoes are installed downward over the anchor plate to inside of shoe retaining plate.
17. Install the adjuster screw assembly between the leading shoe slot and the slot in the trailing shoe and parking brake lever. The adjuster socket end slot must fit into the trailing shoe and parking brake lever.
The adjuster socket blade is marked R or L for the right or left brake assemblies. The R or L adjuster blade must be installed with the letter R or L in the upright position, facing the wheel cylinder, on the correct side to ensure that the deeper of the 2 slots in the adjuster sockets fits into the parking brake lever.
18. Assemble the adjuster lever in the groove located in the parking brake lever pin and into the slot of the adjuster socket that fits into the trailing shoe web.
19. Attach the upper retracting spring to the leading shoe slot. Using a suitable spring tool, stretch the other end of the spring into the notch on the adjuster lever. If the adjuster lever does not contact the star wheel after installing the spring, it is possible that the adjuster socket is installed incorrectly.
20. Inspect your work to make sure it is correct.
21. Install the hub/drum and wheel/tire assemblies and adjust the wheel bearings.
22. Lower the vehicle and check brake operation.
Fig.1 Exploded View of Rear Brakes - 1984 Ford Tempo
Fig 2. Remove the brake shoe upper retaining spring with a suitable removal tool.
Fig.3 Removed retaining spring - note spring direction.
Fig.4 Remove the adjuster lock plate. Note the direction of the tab.
Fig.5 Remove the lower retaining spring.
Fig.6 Remove the Hold Down Spring - note brake spring tool used.
Fig.7 remove the shoe adjuster. Note direction of the adjuster spline.
Fig.8 Remove the hand brake cable.
Fig.9 Remove the final brake shoe.
Fig.10 All removed parts in order and properly oriented for re-assembly.
Apr 17, 2011 | 1984 Ford Tempo
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
Change drum brakes
Brake Shoe: Service and Repair
REMOVAL
1. Raise vehicle and remove rear wheels.
2. Remove and discard spring nuts securing drums to wheel studs.
3. Remove brake drums.
NOTE: If drums prove difficult to remove, retract brake shoes. Remove access plug at the rear of backing plate and back off adjuster screw with
brake tool and screwdriver.
4. Remove U-clip and washer securing adjuster cable to parking brake lever.
5. Remove primary and secondary return springs from anchor pin with brake spring pliers.
6. Remove hold-down springs, retainers and pins with standard retaining spring tool.
7. Install spring clamps on wheel cylinders to hold pistons in place.
8. Remove adjuster lever, adjuster screw and spring.
9. Remove adjuster cable and cable guide.
10. Remove brake shoes and parking brake strut.
11. Disconnect cable from parking brake lever and remove lever.
INSTALLATION
1. Clean support plate with brake cleaner.
2. If new drums are being installed, remove protective coating with carburetor cleaner or brake cleaner.
3. Clean and lubricate anchor pin with light coat of Mopar multi-mileage grease.
4. Apply multi-purpose grease to brake shoe contact surfaces of support plate.
5. Lubricate adjuster screw threads and pivot with spray lube.
6. Attach parking brake lever to secondary brake shoe. Use new washer and U-clip to secure lever.
7. Remove wheel cylinder clamps.
8. Attach parking brake cable to lever.
9. Install brake shoes on support plate. Secure shoes with new hold-down springs, pins and retainers.
10. Install parking brake strut and spring.
11. Install guide plate and adjuster cable on anchor pin.
12. Install primary and secondary return springs.
13. Install adjuster cable guide on secondary shoe.
14. Lubricate and assemble adjuster screw.
15. Install adjuster screw, spring and lever and connect to adjuster cable.
16. Adjust shoes to drum.
17. Install wheel/tire assemblies and lower vehicle.
18. Verify firm brake pedal before moving vehicle.
Aug 12, 2009 | 1997 Jeep Cherokee Country
Remove and replace rear brake shoes on 2004 honda accord
  2. Remove rear wheel assemblies.
  3. Release parking brake.
  4. Remove brake drum.
Rear brake shoe assembly
  1. Using an appropriate brake spring tool, unhook upper return spring from rearward brake shoe.
  2. Push retainer springs IN and turn to remove tension pins.
  3. Lower brake shoe assembly and remove lower return spring.
  4. Remove brake shoe assembly from back plate.
  5. Disconnect parking brake cable from lever and remove brake shoe.
  6. Remove parking brake lever from brake shoe.
To Install:
  1. Install parking brake lever to rearward brake shoe.
  2. Secure lever to brake show with a NEW U-clip.
  3. Pinch U-clip closed.
  4. Connect parking brake cable to rearward brake shoe.
  5. Install self-adjuster lever spring on front brake shoe.
  6. Assemble clevises, adjuster bolt and upper and lower return springs.
  7. Apply a light coat of grease (Molykote 44MA or equivalent) to sliding surfaces.
  8. Install brake shoe assembly onto back plate.
  9. Install tension springs.
  10. Using an appropriate brake spring tool, unhook upper return spring to rearward brake shoe.
  11. Install brake drum.
  12. Install rear wheel assembly.
  13. Lower vehicle.
  14. Adjust self-adjusting brakes by pressing brake pedal several times.
Jul 13, 2009 | 2004 Honda Accord
1999 nissan quest rear brake shoes need changing
help is here:
http://autos.groups.yahoo.com/group/villagerquest/
Drum Removal
  1. Remove the rear wheel and the tire assembly. Refer to Section 204-04 .
  1. Retract the brake shoes and loosen the brake adjuster screw.
  1. Remove the brake drum.
May require big hammer to loosen drum from axle flange. Hit between the the lugs, not on them.
#10 is access plug to back off adjusting wheel.
Item Part Number Description 1 2261 Rear wheel cylinder 2 — Dust boot (part of 2128) 3 2197 Wheel cylinder piston (part of 2261) 4 — Cup (part of 2128) 5 2204 Wheel cylinder piston cup spring (part of 2128) 6 — Wheel cylinder housing (part of 2261) 7 — Brake shoe hold-down pin 8 — Access hole (part of 2212) 9 — Rear brake bleeder screw (part of 2261) 10 — Access hole plug 11 — Rear wheel cylinder bolt 12 2212 Rear brake backing plate 13 — Rear brake backing plate bolts 14 2N790 Parking brake lever clip 15 — Spring washer 16 — Secondary brake shoe and lining (part of 2200) 17 — Brake shoe hold-down spring (part of 2B514) 18 — Lower retracting spring (part of 2B514) 19 2A637 Parking brake lever 20 — Parking brake lever pin 21 2A177 Brake shoe adjusting lever 22 — Adjuster lever pin (part of 2A177) 23 — Primary brake shoe and lining (part of 2200) 24 — Upper retracting spring (part of 2B514) 25 2041 Brake adjuster screw
Shoes Removal
Take a picture and remember how each part goes and attaches
  1. Remove the brake drum, refer to Drum in this section.
  1. Remove the upper retracting spring.
  1. Remove the lower retracting spring.
  1. Remove the self-adjuster.
  1. Remove the hold-down springs.
  1. Remove the parking brake lever clip and the parking brake lever.
Apr 17, 2009 | 1999 Nissan Quest
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
94 landcruiser brakes
Rear DRUM instructions are first If you would Like Pictures and all They Must Be Emailed as TOO LARGE For FixYa's Format im at aol.com
Just use my Knickname@ and let me know where to send.
  1. Raise and support rear of vehicle, then remove wheel and tire assembly.
  2. Remove brake drum. If brake drum cannot be removed easily, insert a suitable screwdriver through hole in backing plate, then push adjuster lever away from adjuster and back of adjustment tension.
  3. Remove tension spring, using a suitable tool, then remove rear shoe hold-down spring and pin. Remove rear brake shoe and anchor spring, Fig. 7.
    1. On Land Cruiser models, remove front hold-down spring using a suitable tool, then disconnect the parking brake cable from the parking brake bellcrank, Fig. 7.
    2. On Pickup, 4Runner, 4WD T100 and 4WD Tacoma models, remove front shoe hold-down spring and pin, using a suitable tool, then disconnect No. 1 parking brake cable from No. 3 parking brake bellcrank.
    3. On 2WD T100 models, proceed as follows:
      1. Remove E-ring, then automatic adjusting lever and C-washer, then parking brake lever. Disconnect brake line from wheel cylinder using a suitable container to catch fluid.
      2. Remove wheel cylinder. Remove following parts from wheel cylinder: two boots, two pistons, two pistons cups and spring.
    1. On models except 2WD T100, remove front brake with strut, then disconnect parking brake cable from front shoe. Remove parking brake cable No. 2.
    2. Remove adjusting lever spring, then the adjuster from front shoe.
    Inspection
    1. Measure brake drum inside diameter. Inside diameter should be 11.61 inches,
      1. Measure brake shoe lining thickness, Fig. 3. Minimum thickness should be .04 inch on models except on T100 models and .039 inch on T100 models.
      2. Inspect brake lining and drum for proper contact and replace drum or shoes as necessary.
      3. Inspect wheel cylinder for corrosion or damage.
      4. Inspect backing plate for wear or damage.
      5. Inspect bellcrank components for bending, wear or damage.
      6. Apply a suitable lubricant to backing plate contact areas.
      Installation
      1. On 2WD T100 models, proceed as follows:
        1. Apply lithium soap base glycol grease to piston cups, pistons and boots.
        2. Assemble and install wheel cylinder.
        3. Connect brake line to cylinder.
      1. Apply high temperature grease to following parts:
      1. Apply a suitable lubricant to adjuster bolt threads and end.
      2. Assemble adjuster to lever, then install adjuster lever spring.
      3. On Land Cruiser models, install parking brake lever cable to parking brake shoe, then attach cable to bellcrank.
      4. On Pickup, 4Runner, 4WD T100 and 4WD Tacoma models, install No. 1 parking brake cable to parking brake lever shoe, then attach the other side of cable to No. 3 bellcrank.
      5. Position front shoe in place with end of shoe inserted into piston, then install shoe hold-down spring and pin using a suitable tool.
      6. Assemble anchor spring to front and rear shoe, then install rear shoe with end inserted in piston.
      7. Install rear shoe hold-down spring and pin, then the tension spring.
      8. If necessary, adjust bellcrank as follows:
        1. Lightly pull bellcrank in direction "A", Fig. 8, until there is no slack in part "B".
            1. Rotate adjusting bolt until dimension "C" is .016-.031 inch.
            2. Lock adjusting bolt with locknut, when connect parking brake cable to bellcrank.
            3. Install tension spring.
          1. Ensure proper parking brake travel.
          2. Pull adjusting lever cable upward, then release and ensure adjusting bolt rotates. If bolt does not rotate, check for improper installation of rear brakes.
          3. Adjust strut to shortest possible length, then install drum.
          4. Pull parking brake lever fully upward. Repeat process several times.
            1. Remove drum, then check for proper clearance, Fig. 4. Clearance should be .024 inch. If clearance is not as specified, check parking brake system.
            2. Install brake drum, then bleed and refill brake system.
            3. Install wheel and tire assembly, then lower vehicle.
FRONT ROTORS & PADS
  1. Remove caliper.
  2. Remove cap and snap ring, Fig. 10, then remove cone washers with tapered punch.
  3. Insert suitable length bolts into flange bolt holes, then tighten bolts evenly and remove flanges.
  4. Remove free wheel hub cover and snap ring, then remove nut, spring washer and cone washer with suitable tapered punch.
  5. Remove free wheel hub body and gasket.
  6. Remove locknut, lock washer and adjusting nut.
  7. Remove axle hub and brake disc as an assembly.
  8. Remove oil seal and inner bearing from hub.
  9. Reverse procedure to install. Torque adjusting nut to 43 ft. lbs., then back off nut. Torque nut to 18 ft. lbs. Using spring scale attached to hub bolt, check that preload is 1.4-12.6. Install lockwasher and locknut, if equipped. Torque locknut to 35 ft. lbs., and recheck preload. Secure lockwasher by bending one tab inward and one tab outward.
  1. Raise and support front of vehicle, then remove tire and wheel assembly.
  2. Remove clip and hole pins, Fig. 9.
  3. Remove anti-rattle spring and shim(s) if equipped, then remove brake pads.
  4. Lubricate caliper housing with suitable brake grease at pad contact points.
  5. Reverse procedure to install.
Jan 28, 2009 | 1994 Toyota Land Cruiser
Chicco C1
hi no it is only forward facing if u have the carry cot or carseat they are rear facing hope this helps
Oct 27, 2008 | Chicco C1 Trio Auto-Fix TS Iceberg...
Chicco trio
I bought i chicco trio 4 years ago and while the carrycot and car seat are in perfect condition, I need replacement wheels for the pushchair. Where can i get replacement wheels for it?
Jul 07, 2008 | Chicco C1 Trio Auto-Fix TS Iceberg...
Chicco C1 Trio Auto-Fix TS Iceberg Umbrella Stroller Logo
259 people viewed this question
Top Chicco Baby Gear Experts
Rommel Balcita
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Chicco Baby Gear Expert? Answer questions, earn points and help others
